Ricoh Aficio 650 Please Help
  • wyched
    • Aug 2025
    I have a Aficio 650,
    It runs fine but on long runs it blanks out (power goes off for a few seconds then comes back on ) when it comes back on, of course it shows jammed paper in system once you clear the jammed paper and reprogram the copier it starts copying again and it does the same thing again cut off and back on
    HELP HELP HELP
    SO MOTE IT BE !
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    Sounds like something could be earthing out against the chassis or maybe a switch is arcing.
      • 23009
      My first reaction is power supply or main power switch.
      • hosennet
        • Mar 2007
        • 145
        Maybe Tray 1 connector dirty
        • Costa
          You are loosing power accidentally. So somewhere on the machine you have short circuit to the ground. It can be anywhere, I had situation on lift sensor on LCT. You should look around in the machine and try to see cuted wire disconnected cable or something similar.
          The power supply board or main PCB is not excluded.
          Sorry Man this is my opinion. Good lack.
          • Mess
            Copier Gawd
            • 81
            This is often caused by a high voltage corona short. Replace the entire corona assy Dont try shortcutting by replacing wire or grid only , just replac the assy. its a cheap part
