MPC'S
  • banginbishop
    grumpy old git
    • Oct 2007
    • 894
    MPC'S
    Hi,
    thanks
    Paul
    Incontinentia Buttocks
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    Nope generally the fusing units on the MPC range are really good.
    Apart from the oil supply roller they will/should go way past there PM yield.
    I think you must just be having some bad luck (or maybe you have a heavy handed customer?).
    • jeffreyozz
      • Mar 2007
      • 52
      Check the timer settings- I have slapped salesmens hands for turning the timers way up so that the machine stays at a full ready state for a long time. The factory settings are sufficient for this machine.
      • banginbishop
        grumpy old git
        • Oct 2007
        • 894
        Fuser belts
        • Cipher
          • May 2006
          • 1309
          The end of that belt's heating roller looks like it's been dragging it's plastic spacer around.
          I would expect the ball bearing to turn freely and for the spacer to stay pretty much fixed against the heat roller under tension.
          • banginbishop
            grumpy old git
            • Oct 2007
            • 894
            Fuser belt
            So far the belts i have changed have all been ok, but by the looks of this one the press roller bushing has stuck. Friction/Heat may have caused it to stick to the press roller (or lack of grease) so what i'm doing now is replacing ricoh's Barrierta grease with their heat heat-resistant grease when i change the belt. The service manual says apply on the press roller so i just change the normal grease to heat-resistant.
            • paulg
              • Jun 2007
              • 278
              I have noticed on many Ricoh fusing roller press and hot there is not enough grease. If you have the time its worth regreasing any fusing unit in either in a new machine or ordered on its own.
