mp 7500 original detection
  • salmandol
    • Mar 2009
    • 107
    hi, i have a mp7500 that detects wrong paper sizes when copying from the adf and exposure glass. at first i replaced adf circuit board before i realized that i was also getting problem with exp glass. i checked all original detection sensor on both adf and under glass - working fine. any help will be greatly appreciated
  • alizen
    • Dec 2008
    • 14
    Re: mp 7500 original detection
    check the adf exposure lamp black plate there is a ir sensor windows open the plate and service the paper size selector switchs or send me your emailid iwill seend you pics
    lift adf
    2 open black plate starting side of adf
    3switches for diffrent sizes services the is ablack mark of tape on a plate will white trun white in to black this spot
    • alizen
      • Dec 2008
      • 14
      check the&nbsp; adf exposure lamp black plate&nbsp; there is a ir sensor windows open the plate and service&nbsp; the paper size&nbsp;selector switchs or send me your emailid iwill seend you pics<BR>lift adf<BR>2 open black plate starting side of adf<BR><BR>3switches for diffrent sizes services the is ablack mark of tape on a plate&nbsp; will white trun white in to black this spot
      • rickg
        Supervisor
        • Feb 2010
        • 22
        What size paper is it saying you need to have. I had a machine ask for 7 1/2 X10 in paper when feeding letter size paper. found one of the setting set to the wrong setting.
        • Cipher
          It's not easy being green
          • May 2006
          • 1309
          It's worth checking out the default settings for detection.
          adf_settings.pdf
          • salmandol
            • Mar 2009
            • 107
            letter on exposure glass asks for a4, letter from adf asks for 16k if i remember correctly... legal asks for 8 1/2x10...all sizes asks for wrong sizes
            • salmandol
              • Mar 2009
              • 107
              [ATTACH]12193[/ATTACH]
              thanks i'll check it out
              • rickg
                Supervisor
                • Feb 2010
                • 22
                check SP5126 and make sure it is set to the correct setting
                • mikadonovan
                  • May 2008
                  • 2931
                  I had this same exact thing happen on a B140. Remove the ADF rear cover and look at the gears that drive the primary feed roller shafts. There is a couple of one way bearings that get dirty/worn and screw up the feed timing. Obviously this would only happen when using the document feeder, though.
                  NEVER ASSUME ANYTHING
