Ricoh 3235c Jam code 011
  • leo34staffs
    copierman
    • Aug 2007
    • 503
    Hi Guys,
    Hope you can offer some assistance with this, I have said machine that when copying, the paper just makes it out of the nip of the fuser rollers and not reaching the fusing exit sensor, this mainly happens on A3 and so when the jam happens most of the paper is still coming from the transfer area, any ideas? there were a couple of other codes 09 and 65 but mainly 011.
    Any help will be very much appreciated.
    Networking skills are advantageous but use of a 3m vacuum cleaner is essential
  • Eric1968
    • 2458
    Re: Ricoh 3235c Jam code 011
    If you're sure all the paper sensors are OK, replace the push switch at the left cover. These switches tend to be unreliable sometimes.
    • leo34staffs
      copierman
      • Aug 2007
      • 503
      Would the push switch failing give me power on jams though?
      • rthonpm
        • Aug 2007
        • 2859
        Those are all in the same neighbourhood of the duplex inverter sensor. Check to make sure nothing's blocking it, or that you don't have any kind of burrs or other blockages in the paper path. It doesn't take much more than a bent mylar or a chip of plastic missing to make everything go wacky.
        • knarfdnul
          • Apr 2011
          • 27
          All MPC models have problems with push switches in brigdes and they end as "Power ON" jams - so that must be the same for 32xxC switches.
          • leo34staffs
            copierman
            • Aug 2007
            • 503
            I swapped over the duplex unit after finding the mylars had been flipped backwards, but then still had a jam, i eneded up swaping the fuser assy aswell and since had no recall, perhaps the one way bearing driving the fuser belt was playing up.
            Thanks for the suggestions.
