mpc2500 vertical lines
  • zappetizipp
    • 9
    Hi everyone.
    Any idea what causes these vertical lines in a4 portrait mode. (see attachment)
    from log:
    pcu b: 74%
    dev unit 40%
    dev. 81%
    cleaning 81%
    fusing 81%
  • Jomama46
    • 2900
    Re: mpc2500 vertical lines
    Not straight enough to be charge roll, I would look at the fuser
    sigpic
    A+; Network +; PDI+
    • coolbeer
      • Jul 2011
      • 100
      Looks like cracks in fuser belt to me.
      • Ollie1981
        Toner Monkey
        • Mar 2008
        • 417
        This is definitely the fuser belt. Had this tons of times.
        If you take the top off the fuser, then remove the large metal frame covering the belt with the non-contact thermistor in, you should be able to see splits in the belt surface.
        The belts on these don't seem to last to their stated life.
        • Max
          • Oct 2011
          • 561
          fuser belt 100%
          • zappetizipp
            • 9
            Hi Again.
            Thank you very much!
            Saved me a couple of hours, changed fuser yesterday, and looked at the old belt..cracks! I think it's the first time i replace fuser before it reaches 100%.
            Thanks again.
