MPC2050 jam in the paper tray 1
    • 37413
    Re: MPC2050 jam in the paper tray 1
    Not notice that this thread is 2 1/2 years old you did. Start a new thread if you want help.
    • wfinn
      • Mar 2011
      • 70
      I have a jamming issue on a MPC2551, went last week & replaced the feed roller & friction pad, tested 50 duplex prints all good, but it has come back in
      So looks like I will need to replace the clutch in the feed drive unit, but can someone post more detailed information on how to replace these clutch's, I swung out the controller board, removed what I think is the feed motor, but can't see how to get to the clutches behind the motor, surely the complete drive unit needs to come out?
      The whole drive unit does come out and it comes out as an assembly. Remove the surrounding screws and it will wiggle out. Replacing the clutches is time consuming and you need to replace all as a set.
      • Zaxxon
        • 608
        No easy fix, replacing these clutches is a bitch...
        Please start you post with brand, model, problem.
        • gestetner tech
          • Nov 2009
          • 45
          #19
          You will find a bulletin on this matter, that clearly shows how to do this.
          I strongly recomend you to get help and lift the machine on to a table :-) that would make it easier.
            • 8133
            #20
            I've got this PDF that teebee1234 posted, I guess i'll have to use that to guide me!
            mpc2050_jam_troubleshooting.pdf
              • 8133
              #21
              Went back today, it was showing a jam customer couldn't clear, all it was is a torn jam just under the reg roller. Phew! I didnt fancy replacing that clutch!!!
              • gestetner tech
                • Nov 2009
                • 45
                #22
                did you change D0391166 2 pcs and D1051164 you have to replace them.
                But could also be that cassett are worn put a schrewdriver in the gap between casett 1 & 2 and se if there are any change in function
                Lars
                  • 8133
                  #23
                  No, after I removed the jam I ran 100 duplex prints without any issues, I was satisfied it doesn't need the clutches, also it does have a low total count, 90k
