Problem with fuser on mpc4500
+ More Options
Posts
  • kassa
    • Oct 2008
    • 79
    [Misc] Problem with fuser on mpc4500
  • teebee1234
    • Jul 2008
    • 1670
    Re: Problem with fuser on mpc4500
    You have exceeded the PM cycle for the fuser (160k), so that should be the first thing you do. The fuser maintenance kit is PMB222160K. The kit has all of the required parts that need to be replaced. If you've never done a rebuild before then I strongly recommend that you take a loaner fuser to the customers and swap it out, then take the worn one back to your shop to work on it. It can be very frustrating to work on and will take patience and some time on your part the first few times. You don't want to service it in the customers office where you will be distracted ("How much longer?", "Is it ready yet?", "Can I just make a quick copy?").
    You are correct in your assumption that the heavier coverage and thick paper is causing faster wear and tear than your normal accounts, just like a car towing a trailer with severe conditions will require more frequent servicing.
    • BLADE
      former propeller tester
      • 478
      what would the user say to neg/pos image reversal
      • hypertech
        Order "402719" complete fuser for a printer just needs to be modified..
        • kassa
          • Oct 2008
          • 79
          Yes I was thinking about this.
          For the European market, you know what is the order of the wires to be moved?
          Thanks.
          • hypertech
            Originally posted by kassa
            Yes I was thinking about this. For the European market, you know what is the order of the wires to be moved? Thanks.
            Sorry mate not sure but if you take off the side cover 1 screen where all the connectors just have a look at that are and copy it. In my area.. We have to move on pink wire on the blue connector.. Cya PM.. me if you need a hand.
            • kassa
              • Oct 2008
              • 79
              Thank you, very nice.
              Bye bye.
              • kassa
                • Oct 2008
                • 79
                Update:
                Yesterday I replaced the whole fuser, but now the customer calls me back telling me that the problem is still present.
                It occurs to me then that the coil assembly ih could be the problem.
                What do you think?
                • Ollie1981
                  Toner Monkey
                  • Mar 2008
                  • 417
                  The customer is setting the machine to run the stock as "Thick Paper 2" (can't remember if this machine has "Thick 3" or not), this usually sorts out most issues to do with ghosting/offsetting on heavy coverage jobs on thick stock.
                  I'd leave the coil as an absolute last resort as it's an expensive part and also it isn't very easy to get at. I've had to replace them in the past but only usually when they've gone completely and taken out their invertor board with them.
                  • kassa
                    • Oct 2008
                    • 79
                    • Captain Scott
                      • Dec 2008
                      • 166
                      "I plan to increase by 2 / 3 points, the temperature of the heat roller by 1.105.30_36 sp and sp 1.105.122_123 for the pressure roller"
                      Reverse the above plan. Stop the page before it hits the fuser, is there anything unusual going on CQ wise?
                      • kassa
                        • Oct 2008
                        • 79
                        I already tried to increase the temperature of the fuser without solving.
                        Unfortunately the problem is not always present so I have a lot of luck to make the proof of which you speak.
                        Thank you for the answer
