AP3800C Memory all Clear (SP5-998)Then SC999
  • copymatebs
    Hi,, we have a AP3800C after performing the SP5-998 Memory clear2 ENG setting, the machine come out with SC999 , i think this is the firmware problem,, anyone can help?? please email me the firmware : copymatebs@yahoo.com TQ
  • tonyd
    sc999
    u need to go into ssp and reset the destination code
      • 23009
      I've managed to avoid doing 'all clears' for most of 20 years. They cause more harm than good. I've not had an 'all clear' ever actually fix anything.
      • paulg
        • Jun 2007
        • 278
        I think you have the right idea but sadly due to tweakers, iffy nv ram units and weird problems with Java modules and other applications loaded on to mfps and printers.
        I have on a few occasions had to use it (mostly as a diagonostic tool and then loaded the saved contents back on to the nvram) but i agree that some people think its the answer to everything which is not a good idea.
        • jours
          Same problem
          I suspect I have the same problem on a customer's AP3800C MF. Tonyd, can you provide any details on what the dest code should be? I'm not really a Ricoh guy but I'd like to fix this one...
