mp9000 jam code 22
  • wikus
    • May 2025
    [Jamming] mp9000 jam code 22
    im getting a jam code 22 continiously on a mp9000.I know the problem is on the exit unit,but where?cleaned one way bearings,cleaned shafts where bearings runs on & also changed all sensors.looks like if something is slowing the exit section.
  • BLADE
    former propeller tester
    • 478
    Re: mp9000 jam code 22
    I guess youve checked the two little rollers above the fuser exit tyres are in position
    • DIONISIS
      • Oct 2008
      • 17
      i have the same problem to a katana mp1350,trying to solve it!!! (j 22)
      DIO-masterprint
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
        • collme
          Ricoh tech
          • 221
          replace the 2 gears which contain the one way bearings between fuser drive and heat pipe. I have to replace at regular intervals as cleaning the one way bearings does not stop them slipping.
          • imaginemoko
            unTrusted Tech
            • Jan 2008
            • 289
            have you try to check this B234 4256 - Drive Shaft sometimes it worn out in the long run... good luck
            fix the customer first then fix the machine... its simple and makes life more easy.
