Ricoh MP2500
  • copiermen
    • Aug 2025
    [Misc] Ricoh MP2500
    We have a MPC 2500 which has gone into error mode, and has a blank screen. It starts to warm up then signals that it has gone into a service call condition, but because it has also got a blank screen we do not know what is up with it. Anyone have any ideas? Many thanks.
  • copyaction
    • Oct 2007
    • 991
    Re: Ricoh MP2500
    HDD
    • ucinn
      • Jun 2009
      • 383
      Re: Ricoh MP2500
      Originally posted by copyaction
      HDD
      If you know the IP address, try connecting to it through the web service. Then you might be able to see what code it is throwing at you.
      • JustManuals
        • Jan 2006
        • 9838
        Re: Ricoh MP2500
        Paul@justmanuals.com
        • sharpmind
          • Sep 2009
          • 478
          Re: Ricoh MP2500
          I have encountered the same problem. What I did first was I swapped the whole operation panel to check if it is good or not.I found out that there was nothing wrong in the operation panel.
          I have rectified the problem by replacing the BICU board and the polygon motor at the same time.Proven and tested!
          • mikadonovan
            • May 2008
            • 2931
            Re: Ricoh MP2500
            These models had a problem with the LCDC going non responsive, but I've not seen a blank one yet. Have you tried another op panel?
            NEVER ASSUME ANYTHING
            • copiermen
              Re: Ricoh MP2500
              We have tried new control panel, no joy, unfortunately have no idea what the IP address is. So looks like polygon motor and BICU board next. Thanks for all your help. Will let you know how we get on.
              • harwin84
                get the IP address from your printer driver
                • mabawser
                  Tech
                  • Sep 2009
                  • 121
                  Re: Ricoh MP2500
                  had this and when looked it has a sc204 code if i remember right and the poloygon mirror motor was causing this!!
                  • copiermen
                    Re: Ricoh MP2500
                    Thanks for that, have ordered polygon and BCIU, will hopefully sort problem.
                    • mustdie
                      • Jul 2011
                      • 26
                      Re: Ricoh MP2500
                      I have rectified the problem by replacing the BICU board ...settle
                      • limo
                        • Jun 2008
                        • 103
                        Re: Ricoh MP2500
                        By replacing the BICU sometimes you an fixed the m/c temporarily . The real cause of the problem is the damaged duplex harness which are grounded and damage the BICU.
