one line appeared with intermitten point in A4 SFE (2035)
  • akbareshghi
    • Sep 2010
    • 261
    [CQ] one line appeared with intermitten point in A4 SFE (2035)
    The copy quality of my 2035 machine is bad.which arePossible causes of this line appearing in copies due to which part(s)?
    this line sometimes disapeared and sometimes more storngly than others
    I think the the problem is due to one of strippers on the fuser unit
    Below is a copy of my scanned image.
    which are your proposed solution for me and other users?
    thanks a lot
    Color printing with lowest cost per page is my love.
  • Jomama46
    • 2900
    Re: one line appeared with intermitten point in A4 SFE (2035)
    Looks more like drum arcing. Pull the drum and see if marks are there.
    sigpic
    A+; Network +; PDI+
    • sharpmind
      • Sep 2009
      • 478
      Also check the hot roller surface for any scratches or marks caused by the toner adhered on its surface.
      • akbareshghi
        • Sep 2010
        • 261
        i cleaned Holder - Pick-off Pawls and spurs and near the holder ID sensor the with wet cloth
        and after that this problem is created
        no marks on the Drum existed and this part(drum) after copying and opening right door is seen cleanly and without any spot
        please guide me troubleshooting this CQ problem
        thanks a lot
        • akbareshghi
          • Sep 2010
          • 261
          how clean the toners on the hot roller
          yes this occured but not in the center of it but also occured in left side of it only
          please guide me about removing scratch and patching hot roller rather than replacing with new one
          thanks a lot
          • sharpmind
            • Sep 2009
            • 478
            thanks a lot
            You can use cardboard or any thick paper, and scrub the hot roller surface carefully.
            When you remove the lower fusing frame, you can find a cleaning roller which cleans the pressure roller.Clean it properly.
            • akbareshghi
              • Sep 2010
              • 261
              the distance between points on the line is fixed (4.5 cm) i change the stripper but my problem was not solved
              hot roller is new and recently was replaced
              i measured the distance between this line appeared on the coies(LEF) and margin of paper that is 10 cm for LEF from margin that close to front door
              this point and 10 cm distance from front is exactly same as positon first spur and pick-off pawl
              I clean these two part and my problem was lowered
              please guide me about one solution that fully eliminate this line and points
              perhaps i should replace them(two above or either only one of them)
              thanks a lot
              spur with part number B004 2310 and pick-off pawl with part number AD02 5021 is displayed below
              in PM you must replace pick-off pawls(both) after 150k
              the following is possible cause of my problem
              1. Remove the drum
              2. Pawl assembly [A]
              • akbareshghi
                • Sep 2010
                • 261
                i saw the dirty similar to one appeared on the copies on front 10 cm on Registration Roller perhaps in this distance route of paper exist toner dirty please guide me cleaning the entire of this route
                POssible cause:
                1- uncleanness of bush of Charge roller
                2- Uncleanness of ID sensor
                3- Uncleanness of Registration Roller
                4- uncleanness of etc
                • akbareshghi
                  • Sep 2010
                  • 261
                  i saw this dirty on the registration roller and after cleaning with alcohol and cotton
                  the problem and line appearing on the copies and print was eliminated
                  thanks for all users that participate in resolving this problems
                  i am very happy because i donot make any mistake during this troubleshooting despite previous mistakes
                  i decided to design most problems that i will encounter in future in Autocad environment to increase quality of Question and resolving problems
                  thanks for other user that consumes valuable times to help others
                  • ccchuah
                    • Mar 2009
                    • 153
                    Try to copy from adf or print from computer and see the lines appears, mostly is the dirty optic mirror.
