Broken drum cup gear ( MPC2500)
  • kayjaig
    • 144
    [Misc] Broken drum cup gear ( MPC2500)
    Hi , I am working on MPC2500, one of the cup gear is broken (See attached photo, gear with red circle is broken), so the drum unit is not driven at all. Is there a easy way to replace it without taking too much parts out? thanks.
  • turbojetboy
    • Aug 2009
    • 279
    Re: Broken drum cup gear ( MPC2500)
    Never seen that before, however have seen a few other faults with the drive unit. It is a big pull apart - you need a good half day and a lot of patience (and a good dose of luck). I suspect you will have to remove the drive assy.
    • Ollie1981
      Toner Monkey
      • Mar 2008
      • 417
      Sorry mate.... easy way? In a word ..... no.
      That drive bracket is a PITA to replace.
      How did the damage occur in the first place as I personally have never seen this gear damaged even on machines with sky high counts? Only thing I can think of is a seized drum unit.
      • daveyball
        • May 2009
        • 314
        Agree with you there even when you get the drive unit out, it's a nightmare to strip and back together, it may be cheaper in the long run to replace the unit, pricey I'm sure.
        • Eric1968
          • 2458
          Just saw the replacement procedure in the service manual : -> HELLL!!!
          Wish you luck on this one!!
          • femaster
            • May 2011
            • 1508
            Yeah, what he said! I feel for you! You are definitely going to need the service manual for this job. Just WOW!
            • Ollie1981
              Toner Monkey
              • Mar 2008
              • 417
              I speak from experience when I say it's a PITA
              I've usually had to replace them when some halfwit has "modified" the connector for a black drum to use as a colour, but not cut enough off the corner of the connector and slammed the pcu into the machine pushing the female end into the drive bracket.
              • Oze
                Ricoh Fanboy
                • Jul 2008
                • 1663
                Nightmare job...
                I had to replace the drive unit a few weeks ago and only had a second hand unit in a traded machine...so I had to strip the drive assy out of both machines...fit the used unit to the customer's machine only to find that the used unit had a fault...ordered a new drive assy(very pricey)and fitted it to the customer's machine.
                I am now by default the company go to man for MPC2500....great
                • Oze
                  Ricoh Fanboy
                  • Jul 2008
                  • 1663
                  And THAT was the reason that I had to do the job in the first place...and the tech that did it now works for Ricoh...go figure
                  • jonezy999
                    just one copy??
                    • Feb 2010
                    • 952
                    Yep, exactly what they said, unfortunately.
                    I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
                    • kayjaig
                      • 144
                      Thanks for all, will take a good day to work on it. Hopefully it will not become our part machine. ha ha haa....
