I have a Savin C3535. When you go to scan the buttons don't align, with where you have to hit the screen. I 'm not trained on Savins, I'm trying to help out a friend of a customer. Any help would be appreciated.
Scan screen mis-alignment/C3535
Re: Scan screen mis-alignment/C3535
As in the screen/buttons aren't appearing in the right position or you have to press the screen in an odd spot to select a button?
If the latter, you could try doing a touch screen calibration.
To get into the calibration screen, <clear modes>, 1-9-9-3, <clear/stop> x 5. This should pull up the diagnostic menu, 1 for touch screen adjust. Then using a small dull pointed item calibrate the screen.
If it's the first, I have no suggestions aside from firmware update/reloading.Have you tried turning it off and on again?
The Alignment procedure will probably get you by for a VERY short time. This is a known issue with this line, and the touch panel (not the LCD screen itself) will need to be replaced. See attached service bulletin.Attached FilesA Ricoh Service Tech for 7 year. A Konica Minolta Service Tech for 7 years. Now, KM service manager for 4 years.
My Ricoh knowledge is slowly dwindling away at this point. Many things have been lost to time...Comment
If it's the first, I have no suggestions aside from firmware update/reloading.It's 106 miles to Chicago. We've got a full tank of gas, half a pack of cigarettes, it's dark and we're wearing sunglasses.
Hit it.Comment
Nope, never. Not on the copiers anyways. I also service Tidel safes that have a touch screen and they seem to fail quite frequently. But, usually when they fail they don't just become misaligned they become unresponsive to any touch.Have you tried turning it off and on again?
Holy crap! This has been a known problem for a few years now. The replacement touch screen part number is B223 9900.It's 106 miles to Chicago. We've got a full tank of gas, half a pack of cigarettes, it's dark and we're wearing sunglasses.
Hit it.Comment
Thank,s to all for responding .I was able to re-align the toucpad, and left the customer a copy of the service bulletin. The bulletin states that the touch pad is problamatic. I left it up to her to go for a new touch panel screen,Their T & M.Thank,s AgainComment
