Scan screen mis-alignment/C3535
  • Digicomm
    • Sep 2010
    • 65
    [Misc] Scan screen mis-alignment/C3535
    I have a Savin C3535. When you go to scan the buttons don't align, with where you have to hit the screen. I 'm not trained on Savins, I'm trying to help out a friend of a customer. Any help would be appreciated.
  • Jaxom
    Lead Technician
    • Apr 2011
    • 62
    Re: Scan screen mis-alignment/C3535
    As in the screen/buttons aren't appearing in the right position or you have to press the screen in an odd spot to select a button?
    If the latter, you could try doing a touch screen calibration.
    To get into the calibration screen, <clear modes>, 1-9-9-3, <clear/stop> x 5. This should pull up the diagnostic menu, 1 for touch screen adjust. Then using a small dull pointed item calibrate the screen.
    If it's the first, I have no suggestions aside from firmware update/reloading.
    Have you tried turning it off and on again?
    • femaster
      • May 2011
      • 1514
      The Alignment procedure will probably get you by for a VERY short time. This is a known issue with this line, and the touch panel (not the LCD screen itself) will need to be replaced. See attached service bulletin.
      • Digicomm
        • Sep 2010
        • 65
        Thank You for the replys .I'll let you know how i make out Monday .Have a nice weekend.
        • TonerMunkeh
          Professional Moron
          • 3865
          You've never seen a touch screen fail on these?
          Hit it.
          • Jaxom
            Lead Technician
            • Apr 2011
            • 62
            Nope, never. Not on the copiers anyways. I also service Tidel safes that have a touch screen and they seem to fail quite frequently. But, usually when they fail they don't just become misaligned they become unresponsive to any touch.
            • TonerMunkeh
              Professional Moron
              • 3865
              Holy crap! This has been a known problem for a few years now. The replacement touch screen part number is B223 9900.
              Hit it.
              • Jaxom
                Lead Technician
                • Apr 2011
                • 62
                Mm, I have been aware of the problem via the tech bulletins, I have just never experienced it.
                • Digicomm
                  • Sep 2010
                  • 65
                  Thank,s to all for responding .I was able to re-align the toucpad, and left the customer a copy of the service bulletin. The bulletin states that the touch pad is problamatic. I left it up to her to go for a new touch panel screen,Their T & M.Thank,s Again
                  • WH007
                    • 9
                    thanks guys this was real handy cleaned then did calibration prefect now and if it comes back I'll order the panel.
                    • zames77
                      Tweak it till it breaks!
                      • 121
                      I'd order the part now, it will most definitely come back in.
                      • femaster
                        • May 2011
                        • 1514
                        Agreed... It's a given. Once they start acting up, it's generally only a matter of days at the most...
