mpc2551 can't connect to network
  • fritzyas
    • Jul 2011
    • 73
    we have a problem with mpc2551, we already have changed the controller board but still the machine can't be ping. Tried to ping 127.0.0.1 and it is successful.we updated all the firmware already. any info about the problem. thank you in advance.
  • tonnerboy
    • May 2011
    • 212
    Re: mpc2551 can't connect to network
    What IP address are you using in the MFP??? Is it 127.0.0.1????
    Have you tryed to conect your Laptop it to the machine (directly)???
    • ss12
      • 289
      have you tried leaving the machine with dhcp on and seeing if it picks up an ip address?
      • fritzyas
        • Jul 2011
        • 73
        the ip add of the machine is 192.168.1.23,255.255.255.0 ,while my laptop is 192.168.1.24,255.255.255.0, gateway is 192.168.1.1. ,I used crossed cable to connect to the machine. i have used only 127.0.0.1 to test the machines nib and it is successful.
        • fritzyas
          • Jul 2011
          • 73
          it doesn't pick up any ip address
          when using dhcp
          • knightfall
            • Jul 2006
            • 633
            if you have put in the static ip address what does the config sheet say the ip address is?
            if the ip address that you put in is different that the ip address you put in than the controller is not accepting your ip input and that probably is the nvram not accepting so that needs to be replaced.
            If the config sheet does have the ip address that you put in then I would check if you are able to web into the controller than try updating all the network firmware. Have you tried using another ethernet cable have seen that cable not ping the copier but all link light is lit. Hope this helps, good luck.
            Get your facts first, and then you can distort them as much as you please.
            • TonerMunkeh
              Professional Moron
              • 3865
              Can you scan a config page and put it on here please?
              Hit it.
              • fritzyas
                • Jul 2011
                • 73
                ok I post the config page tomorrow. thanks
                • fritzyas
                  • Jul 2011
                  • 73
                  when i used a static ip then i print the config page, the ip add will appear on the config page. all the firmwares are already updated. the controller board was replaced with new one.
                  • ss12
                    • 289
                    If you've managed to print via crossover cable all signs point to a network problem.Any input from the customers IT dept?
                    • Eric1968
                      • 2458
                      If your trying to ping 127.0.0.1, you're pinging your own computer, and yes, that's most of the time a succesfull ping. Check all IP-settings (IP-adres Subnet Mask, Gateway). Is your machine equipped with a Gigabit-NIC, then you can try to set the NIC manually to 100 Mbps.
                      • neergish
                        • 177
                        Check to see if the IEEE802.1x Authentication(ethernet) is set to inactive.
                        Does the machine have a fax installed, I was having the same issue with MPC2050 wich was resolved just by reseating the fax board when i went to replace the controller, Ricoh tech support couldnt figure it out why either but might be worth a shot.
                        "See if you can rent a spring hook and a phillips screwdriver it will make your life that much easier..."
                        • teebee1234
                          • 1670
                          Whoa, first thing to check is that the NIC is enabled in sp5985-1 (set to 1). When the print controller is installed, that value has to be set (default is '0'). Someone may have forgotten to do that.
                          *FYI- As a side note to everyone (some of you are probably already aware of this), when the new mfp's that have the NIC preinstalled at the manufacturer are shipped, they are now setting sp5985-1 to "2". This allows printing and pinging but blocks access to the WIM. You will have to set it to "1" if your setup people miss it.
                          • femaster
                            • May 2011
                            • 1466
                            Wasn't aware of that, thanks. Now if only I can remember that...
                            • fritzyas
                              • Jul 2011
                              • 73
                              Thank you for all of the ideas, It was very helpful in the analysis of the problem. Updated the firmware - all firmware.That solved the issue.
