Purchased a used Ricoh 3045 Super G3 from a bank auction with hard drive removed so I purchased a comparable hard drive from e-Bay and plugged it in (did not format).
Plugged in USB & Ethernet cable, downloaded & installed PCL 5e Driver, PCL6 Driver for Universal Print & Printer Switcher and installed. Tried all the combinations I could imagine (not much) but only the copier is working. Printer will not read from CPU. I have been fiddling with this thing for eleven months.
What steps would you suggest to enable this machine?
