Need direction
  • dknap
    [Misc] Need direction
    Purchased a used Ricoh 3045 Super G3 from a bank auction with hard drive removed so I purchased a comparable hard drive from e-Bay and plugged it in (did not format).
    Plugged in USB & Ethernet cable, downloaded & installed PCL 5e Driver, PCL6 Driver for Universal Print & Printer Switcher and installed. Tried all the combinations I could imagine (not much) but only the copier is working. Printer will not read from CPU. I have been fiddling with this thing for eleven months.
    What steps would you suggest to enable this machine?
  • Eric1968
    • 2458
    Re: Need direction
    Is the machine equipped with the Printer/Scanner SD-card? Maybe they also removed this SD-Card. It should be located behind a small metal cover just above the network cable.
    • dknap
      Re: Need direction
      The three slots; C1 printer/scanner, C2 PostScript3 or Data Overwrite & C3 service are all empty. So are slots 1 & 2
      • dknap
        Re: Need direction
        The three slots are empty. C1 - printer / scanner, C2 - data overwrite security or postscript3 & C3 - service slot.
        Also slot 1 & 2 are empty
        Are you thinking an additional investment will be required?
        Thank you Eric for your input.
        • femaster
          • May 2011
          • 1504
          Re: Need direction
          Also, there should be selection buttons on the operation panel of the machine labeled printer and scanner; located just below the Fax button if I recall correctly. If these button are not there, then a print/scan option was never installed, and thus can not be used to print or scan.
          • logrady2331
            • Feb 2011
            • 301
            Re: Need direction
            Call a technician out and pay him to fix it................................................ .just sayin'.
            • logrady2331
              • Feb 2011
              • 301
              Re: Need direction
              Can you ping it and get to the web interface?
              • dknap
