aficio main motor
  • cleardata
    • Jul 2011
    • 137
    aficio main motor
    hi. i have lots of deffective (sc440) main motor for aficio 1045 and 2045 (old models). may i know what's causing it to malfunction? is there a way to prevent it from malfunctioning? thank you.
  • Jomama46
    • 2900
    Re: aficio main motor
    Ive had plenty of the 440 codes but never had to replace a motor. Its always been a locked fuser, pcu or developer.
    sigpic
    A+; Network +; PDI+
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • vargue
        • Oct 2011
        • 404
        wellcome then i faced this threat befor in aficio3045 in feeding motor it's running but when yo but your hand on motor when rolling it's stop. i sinking motor in benzen one more time then try it's works for me but detect that motor causes that problem .if yo have overload in any positions it's not vail.
        • ccchuah
          • Mar 2009
          • 157
          Stripe out the motor board until you see the motor coil which solder to the pc board, move the metal wire, you will notice the wire was broken, resolder it and the motor was usable again.
          • cleardata
            • Jul 2011
            • 137
            thank you for your reply. after i replaced the main motor when sc440 appeared on my machines, the machines works fine again without replacing or touching other parts. other techs said that it's one of the weak parts of these models but i think there is a solution to this. some even advised me to take out the bypass if it's not being used to lessen the load of the main motor.
            • cleardata
              • Jul 2011
              • 137
              thank you ccchuah. i will try your solution.
              • TonerMunkeh
                Professional Moron
                • 3865
                Weak part? I've never had to replace a main motor on an Adonis and can't think of any occurences of any of the other members of my team having to either. Are you using OEM parts, toner and developer?
                Hit it.
                • femaster
                  • May 2011
                  • 1514
                  Originally posted by TonerMunkeh
                  Weak part? I've never had to replace a main motor on an Adonis and can't think of any occurrences of any of the other members of my team having to either. Are you using OEM parts, toner and developer?
                  I'm with TonerMunkeh, we've serviced a lot of this model, along with it's newer counter-parts, and have never had a problem with the main motors dying.
                  • vargue
                    • Oct 2011
                    • 404
                    this threat revealed with machine working since 6 or 7years .notice we are working in used machine
                    • cleardata
                      • Jul 2011
                      • 137
                      yes i am. there are techs serivicing these models in other cities who experiences the same problem. mine i have about 10units deffective main motor. but i will try the resoldering solution of ccchuah. thanks to all your replies.
