Mag roller cleaning
  • Iowatech
    Not a service manager
    • 3930
    #16
    Re: Mag roller cleaning
    Mr. Clean brand Magic Eraser sponges, a couple drops of alcohol per wipe although I've heard water works well, too.
    • Athlontini
      • Jun 2012
      • 269
      #17
      Originally posted by andy227
      Are you all talking of cleaning the roller stripped out, in which case you can be as harsh as you want, or, about cleaning the mag roller in situ, in which case you have to be ULTRA careful not to damage the end seals and not to run any liquid inside the dev unit ???
      People do this?
      I'll use a wire brush for the heavily coated rollers, otherwise a cloth with a small amount of belt cleaner on it works wonders.
        • 23010
        #18
        My brand new favorite, paraffin lamp oil. In the early days it was Dispersant, until it got really hard to get. Chemically I suspect that there isn't much of a difference.
        It's the best thing I've found for loosening adhesive from metal, drums, plastic, (but not rubber: degrades the rubber). If you're going to clean a drum keep it out of contact with the blade until you're rinsed it with alcohol.
        It works pretty good on developing rollers too. =^..^=
