Mag roller cleaning
  • jonezy999
    just one copy??
    • Feb 2010
    • 952
    Mag roller cleaning
    Have noticed a few post lately regarding cleaning mag rolleers. I just wanted to know what methods techs are using? I have tried the wire brush and just scrubbing with paper, but the best method I have found is using a paste type metal polish like Autosol on a soft cloth once the mag roller has been vacuumed off. I also use this same polish on facing and all other transfer belt rollers.
    I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
  • Oze
    Ricoh Fanboy
    • 1663
    Re: Mag roller cleaning
    Green plastic pot scourers here.
    You need to be careful using them however as they're VERY responsive to the amount of force used.
    In other words a gentle scrub for mag rollers and a bit more muscle for fuser cleaning rollers
    • TonerMunkeh
      Professional Moron
      • 3865
      Aye, pot scourers all the way. For transfer and fusers rollers a slight dip in IPA solvent or rubber cleaner works a treat.
      Hit it.
      • Counsel
        • Aug 2011
        • 530
        For mag rollers it just depends how crappy they are if they aren't bad ill just use crumpled paper, otherwise I have a small shoe polish brush that has bristles like a toothbrush basically they are soft but stiff enough to clean the roller, if they are really junky i will use the green scour pad lightly, otherwise I dont have to many issues with them. On the smaller units with the transfer belt that has the 3 metal shafts inside I will take them apart remove the center small rod and clean them with goof off its a little strong it will melt the plastic if you spill so i just dab some on a rag and rub them clean I havent come across anything that will remove the pasted on toner besides this method, i will follow up with a little alcohol to wipe off excess goof off then make sure they are dry before putting the transfer belt on. As far as fuser cleaning rollers I have never had to clean one I just replace them at PM and they usually go from PM to PM without any issues, if it fails before there is usally other fuser parts that fail also so I just replace we arent stingy on parts if somethings bad you just put a new one in and save yourself the trouble.
        • Zeldaman
          • Mar 2011
          • 946
          • zed255
            How'd ya manage that?
            • 1024
            I use a heavy duty 'Scotch-Brite' pad.
            Scotch Brite
            • RG1964
              • Jul 2009
              • 56
              I use the same pad. Never had any problems.
              Some use types of solvent, but it 'kills' the new types of plastic.
              • Zeldaman
                • Mar 2011
                • 946
                Hi there!
                Thank you very much zed255, this is common to me..
                Greetings...
                • ucinn
                  • Jun 2009
                  • 383
                  wire brush here.
                  • neergish
                    • 177
                    I like the paper method myself, with a little bit of used dev for grit. But I do carry a scotch brite with me for those heavy jobs.
                    "See if you can rent a spring hook and a phillips screwdriver it will make your life that much easier..."
                    • nmfaxman
                      • 1702
                      Scotchbrite and then regap doctor blade to a tight 0.35mm on both ends. Marks don't come back.
                      • Lagonda
                        • Aug 2008
                        • 1649
                        Chalk another one up for the green pot scourer, but you have to pay the extra money for a quality 3M Scotchbrite. If you use metho with the cheap ones you find the dye runs and you end up with green hands.
                        • Cipher
                          It's not easy being green
                          • May 2006
                          • 1309
                          Normally I use a piece of extra fine aluminium oxide cloth backed sandpaper.
                          Takes minimal effort and leaves a polished like finish because the grain is so fine.
                          The cloth backing makes it flexible and very hard wearing, even when wet.
                          *Also works well to clean snake skin oil rollers and bare metal cleaning rollers.
                          • RRodgers
                            • Jun 2009
                            • 1947
                            When I do use something I use paper. Rarely ever do I have too, maybe on a older Lanier here and there.
                            • andy227
                              • Jan 2013
                              • 219
                              Reading with interest all these suggestions, but one important thing got my curiosity that nobody mentions. Are you all talking of cleaning the roller stripped out, in which case you can be as harsh as you want, or, about cleaning the mag roller in situ, in which case you have to be ULTRA careful not to damage the end seals and not to run any liquid inside the dev unit ???
