ricoh c2228
  • digicor
    • Jul 2008
    • 1153
    ricoh c2228
    This machine will not copy/print on command it just sits there and thinks...
    with or without hdd,reset memory chips,reset with # and * buttons,no luck.
    the fuser just turns and no copy no print no code out?????
  • Eric1968
    • 2458
    Re: ricoh c2228
    Maybe the machine has some limitations enabled? Like color copying/printing?
    • digicor
      • Jul 2008
      • 1153
      Re: ricoh c2228
      no limitations, it was working just yesterday, i have been told it might be the main control board...
      • Eric1968
        • 2458
        Re: ricoh c2228
        Does the machine feed the original through the ADF?
        • digicor
          • Jul 2008
          • 1153
          Re: ricoh c2228
          yes it feeds
          • Eric1968
            • 2458
            Re: ricoh c2228
            Firmware up to the latest version? Maybe a reload helps.
            • sakura
              • 132
              Re: ricoh c2228
              Had it been any driver updates recently? Any printer server software updates? It can't just stop scanning - something went wrong due to something. As mentioned before - update a firmware to the latest, check all of the settings. Should help.
              • George J
                • 107
                Re: ricoh c2228
                I had this once and strangely fixed it when I replaced the fuser.
