AFICIO DSM622 with DF75
  • muaazgujjar
    • 67
    [Jamming] AFICIO DSM622 with DF75
    It is an AFICIO DSM622 with constant jamming in DF.Scenario is :
    When operator add double sided papers in DF and choose the 2nd option 2/2 and press the print/copy button.The DF throws the paper in the lower bin and there comes a n original jam in DF and a blank page comes out in exit tray.agin the operator removes jam and add the originals in DF and machine strts copying both sides but the 1st page on both sides but 2nd page is missing.
    I am afraid that there must be an option which is wrongly selected by the operator.Any help please.
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: AFICIO DSM622 with DF75
    The registration or exit sensors will be dirty. Strip it down and clean the sensors / patches and it'll be sorted.
    Hit it.
    • Jomama46
      • 2900
      The reverse gate may be sticking in the up position. Take the back off and find the end of the reverse gate. There is a rubber cushion that has to be cleaned. The solenoid cant pull the gate down to the reverse position if the gate is stuck to the frame.
      sigpic
      A+; Network +; PDI+
      • sandmanmac
        • 3981
        Agreed. I usually just remove the pad/cushion all together, but it's easy enough to do without removing any covers
        • CrapAimer
          • 296
          The gate will be stuck as the previous have said, could clean should do the trick
          • femaster
            • May 2011
            • 1514
            Agreed with everyone about gate being stuck, have seen this many times. Generally what I do is put a small dag of grease on the cushion, the problem never comes back.
            • muaazgujjar
              • 67
              Thanking you all my seniors.
              I have got the issue.Now the unit works fine.
              I am obliged.
              • TonerMunkeh
                Professional Moron
                • 3865
                What was actually the problem?
                Hit it.
