MPC4000 Strange jamming..
  • Vioksrall
    • Sep 2010
    • 84
    The machine keeps jamming either at exit, before fusing unit or sometimes at registration area. Sensors are all ok by checking through SP mode. I replaced Paper Feed Unit, Transfer Belt; Fusing Unit and IO Board. Almost one month now but I'm run out of idea what to do. Anyone has experience same what I have? Please help. Thank you.
  • teebee1234
    • Jul 2008
    • 1670
    Re: MPC4000 Strange jamming..
    What are the jam codes listed in the SMC report?
    • Ollie1981
      Toner Monkey
      • Mar 2008
      • 417
      Does it have a finisher and bridge unit installed?
      • Vioksrall
        • Sep 2010
        • 84
        Thanks for the reply. The machine doesn't have finisher and bridge unit.
        • neergish
          • 177
          All I can think of off hand is have you tried adjusting the fuser entrance guide plate to its widest position?
          "See if you can rent a spring hook and a phillips screwdriver it will make your life that much easier..."
          • Counsel
            • Aug 2011
            • 529
            Some of those models did have faulty exit sensors at the fuser, usually give off a no paper A-B-C indication even when paper is in the machine. Otherwise the only other jam issues i get are from bad feed rollers, or bridge units and Sometimes ADF issues from paper dust.
