Aficio 2238 - no paper sign on.
  • andrewdecruz
    • Jul 2009
    • 74
    Dear all,
    I have a Ricoh Aficio 2238 which shows intermittent "no paper sign on" especially in the morning.
    The thing is, when this problem occurs, the customer will have to pull out & then push in the cassete tray to clear the "no paper sign ".
    Any help is appreciated.Thanks
  • Polarbear
    • Feb 2012
    • 1070
    Re: Aficio 2238 - no paper sign on.
    Sounds to me like there is a problem with the paper lift mechanism. On some machines (when they get older) they don't lift the paper enough as the machine is consuming sheets. It could also be that there is something else wrong with the paperlift so that the plate drops back down while copying is in progress, which will make the machine think that the paper is finished. When you open and close the tray, the machine lifts the paper back up to the paper end sensor and the machine "sees" the paper again.
    I would check the paper lift mechanism to see that something is not broken or malfunctioning.
    Press the GREEN button!!
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • Jomama46
        • 2900
        I would start by replacing the paper lift motor
        sigpic
        A+; Network +; PDI+
        • sandmanmac
          • 3964
          I have found a few of these that the paper tray becomes warped or somehow out of line (due to age I suppose), and they just don't always make good contact with the switches at the back, and pressing in on the paper tray, or closing it a little more firmly allows the tray to lift. There may be a better fix, but I've solved it by simply sticking some foam padding on the rear of the tray in line with the switches to allow for better contact between them and the tray
          • nmfaxman
            • 1702
            The Clip behind the drawer is broken or the holder in the frame is cracked, so the drawer pops out just enough that the paper size sensors lose contact.
            Usually happens to Drawer #2.
            It is caused by customer slamming drawer full of paper.
            • teebee1234
              • 1670
              x2.
              attached are the tech bulletins addressing this on both the 2238c and 3245c (2 different fixes for the same issue).
              • femaster
                • May 2011
                • 1460
                Originally posted by teebee1234
                x2.
                Something must have happened to the 2238C bulletin file, as all I get is a blank page when opened...
                • Jomama46
                  • 2900
                  same here
                  sigpic
                  A+; Network +; PDI+
                  • teebee1234
                    • 1670
                    Sorry about that, I'll repost it shortly. Here you go...
                    • andrewdecruz
                      • Jul 2009
                      • 74
                      Thanks Teebee...You are the best..
                      The problem was as you mention. I did the modification (seal) at the rear of the tray & the "no paper sign on" dissapeared for good.
                      Thanks a million.
                      Also thanks to the rest of the guys here who replied my thread.
                      Cheers
                      • andrewdecruz
                        • Jul 2009
                        • 74
                        Thanks Teebee1234...
                        I managed to did as you mentioned & solved the problem. It turned out to be paper lift lever which was not activated when the cassete was pushed in. I added a "seal" at the rear of the cassete & the "no paper sign on" dissapeared!
                        Thanks a million & also to the rest of you for your valuable opinion!
                        Cheers!
                        • teebee1234
                          • 1670
                          Glad you got it fixed, though most of the credit needs to be given to the guys (Polarbear, sandmanmac and nmfaxman) that posted first with the correct solutions. I was fortunate to have the relevant bulletins that addressed your issue.
