Aficio 200 drum
  • micktill
    • Jan 2008
    • 32
    Aficio 200 drum
    I have an old aficio 200 that I need to replace the drum unit on its held in on the top by a bar and to pressure plates which I can manualy turn by taking the board off at the back is there a code that cycles it because that would be a lot easier
  • Luther
    • May 2006
    • 682
    With the front door open and the machine powered up cheat the front door switch and the machine will cycle then you should be able to pull the drum unit out,hope this helps
    • johnny32
      • Oct 2007
      • 102
      carry out sp-5-943 hp compression which return charge roller to home postion before opening front cover to remove pcu
