Ricoh MPC2500 Firmware
  • azrael
    • Aug 2025
    I need the firmware for the Ricoh MPC2500. Please email me at mitch_kt@hotmail.com
    The problem I am having with the copier is that after about 100 prints the copies are totally faded and the machine does "Loading Toner" on occasion without a new toner added. I have changed the Developing Unit , New Toner, inspected the Toner Pump and verified that the toner is turning in the machine. The problem cleared when I changed the developer or Developing unit but after about another 100 copies it starting printing faded again. I read on the forum that a possible solution is to update the firmware but I no longer have access to Ricoh firmware , our company switched to Duplicator sales only.
  • tjvincent
    • 280
    Re: Ricoh MPC2500 Firmware
    Try removing the shutter on top of your laser unit.
    • Eric1968
      • 2458
      The toner pump contains a clutch that sometimes failes. Replace the toner pump. If you replace the dv-unit, the machine has enough toner for that moment. After 100 copies or so it's going to add toner. Can't find any RTB about this.
      • Gift
        • Mar 2011
        • 2459
        I'd also say this is not FW related - it's easy a faulty clutch (something you can't usually determine via inspection) or an issue with the shutter (there was indeed a FW fix, but that was ages ago). Maybe the thread starter could post the FW versions of his machine to determine if these are old or not.
        • azrael
          This is what I was thinking this also but I read somewhere on this forum that upgrading the software would fix the shutter problem plus the firmware has never been updated on this machine. I will most likely just go ahead and remove the shutter on Monday.
          thnx for response
          • Eric1968
            • 2458
            thnx for response
            In fact, it should be simple to diagnose this problem. If the machine is going to load toner after 100 copies you should see a change in the Vt-value. If the value is too high, the dv-unit needs toner. The machine will start to add toner using the toner pump. If the clutch in the toner pump is faulty, the dv-unit doesn't get enough toner.
            • rsyarcia
              Hair Straightener Tech
              • 711
              X2, this is always the problem with add toner,etc. for this model. Always check the toner pump,Development drive motor-CMY and hose. isolate it in using the good toner pump. If i am right yellow to black - cyan to magenta pumps are interchangeable.
              Nobody is perfect..
              • sim22
                • Aug 2011
                • 8
                try cleaning toner supply pipes, had a few problems with them causing the same fault. Need to remove at both ends + blow clear
                • Oze
                  Ricoh Fanboy
                  • Jul 2008
                  • 1663
                  Clear NV ram/Engine.
                  Gotta love the new posters who straight up ask for firmware...hide like a fucking Rhino and balls like steel.
                  • Llama God
                    • Mar 2009
                    • 1353
                    I also need the firmware, the doc feed rollers are dirty.
                    • Eric1968
                      • 2458
                      Yeah, clearing the NVRAM solves it... I'm almost 100% sure that an NVRAM-clear won't solve this issue. Check the manual : NVRAM-resets are only to be done when the machine behaves erratic. That means strange SC's and error messages that do not make sense. Well, a faulty toner pump assy is NOT erratic behaviour.
                      • Llama God
                        • Mar 2009
                        • 1353
                        You could try doing a forced toner supply or two until the density's right and then initialising the TD sensor.
                        This won't work if the pump's cattled, of course.
                        • Oze
                          Ricoh Fanboy
                          • Jul 2008
                          • 1663
                          Bites tongue........
                          • Llama God
                            • Mar 2009
                            • 1353
                            Fucksake...
                            • azrael
                              The current firmware is
                              System B2385601M 1.62.1
                              Engine B2385530J V1.11:01
