Ricoh MPC2500 Firmware
  • azrael
    #16
    Re: Ricoh MPC2500 Firmware
    Originally posted by Eric1968
    In fact, it should be simple to diagnose this problem. If the machine is going to load toner after 100 copies you should see a change in the Vt-value. If the value is too high, the dv-unit needs toner. The machine will start to add toner using the toner pump. If the clutch in the toner pump is faulty, the dv-unit doesn't get enough toner.
    I have Changed the Clutch and the problem persisted. I also have checked to make sure that the toner bottles are turning in the copier.
    • Llama God
      • Mar 2009
      • 1353
      #17
      Have you changed the pump? You need to change the pump. It's probably the pump.
      Get a pump.
      • Gift
        • Mar 2011
        • 2459
        #18
        Not to forget the mylars inside the toner hopper^^
        • Llama God
          • Mar 2009
          • 1353
          #19
          How could I?
          • Gift
            • Mar 2011
            • 2459
            #20
            Originally posted by azrael
            The current firmware is
            System B2385601M 1.62.1
            Engine B2385530J V1.11:01
            The laser shutter issue should be solved with the firmware you're using - it's quite outdated though..
            Engine FW history:
            V1.17:01
            Other change
            1. Jam 1 (Cover open) occurs frequently in the bridge unit. Please refer to RTB#RB230-072 for more details.
            2. When the machine is in the paper end condition during limitless feed mode, the machine does the next job faster than the previous job.
            Symptom corrected:
            Under the following conditions, the final page or the pages near the end of the 1st copy are stapled into the 2nd copy.
            1. The customer sets "Staple" on the printer driver and makes two or more copies.
            2. Paper end occurs on the final page or near the end of the 1st copy.
            V1.16:01
            Other changes:
            The detection timing of ADF errors was changed to reduce unnecessary occurrences of SC620.
            V1.15:01
            Symptom corrected:
            If a finisher jam occurs during the stapling of a network printing job, Jam 17 will be triggered once the job resumes (during recovery printing).
            V1.14:01
            Symptom corrected:
            Minor bug corrections.
            V1.131:01
            Other changes:
            The parameters for white level adjustment were optimized to prevent unnecessary occurrences of SC142 (white level detection error).
            V1.12:01
            Other changes:
            Supports the D042 model.
            important: To apply this change, install all of the following firmware:
            • System_Copy firmware ver 1.64 or later
            • Engine firmware ver 1.12:01 or later
            V1.11:01
            Symptom corrected:
            1. The PM yield setting is not at the default value (refer to RTB #RB230020 for details).
            2. The machine might stall during a duplex job under the following conditions:
            • The job is sent from the EFI controller
            • The operator uses an external charge device with an decrementing counter.
            1. Light image density or white bands occur (the laser optics shutter does not open correctly).
            V1.10:01
            Other changes:
            Improved the image quality in halftone areas printed out with the TWAIN driver and EFI controller.
            V1.09:01
            Other changes:
            The occurrence conditions for SC300/301/302/303 (AC charge error) were optimized.
            1.081:01
            Symptom corrected:
            1. The machine may keep running if an interval process control self-check is done during a job that uses different engine speeds.
            2. Other minor changes were made to improve reliability.
            Other changes:
            1. The settings of the following SP modes were changed for China models only:
            • SP7-952-002: from 133703000 to 66852000
            • SP7-952-003: from 162112000 to 81056000
            • SP7-952-004: from 200554000 to 133703000
            • SP7-952-012: from 160000 to 80000
            • SP7-952-013: from 160000 to 80000
            • SP7-952-014: from 240000 to 160000
            1.07:01
            Other changes:
            1. Software changed to support the Korea model.
            2. The default setting for Sp7-952-001 was changed to 300831000.
            3. The default setting for Sp7-952-011 was changed to 360000.
            4. Process control was changed to decrease the waiting time and increase the accuracy of toner concentration calculation.
            1.05:01
            1st Mass production
            • Llama God
              • Mar 2009
              • 1353
              #21
              Laser shutter? Take it off! Then replace the pump...
