Ricoh MPC2500 Firmware
azrael
Re: Ricoh MPC2500 Firmware
Engine FW history:
V1.17:01
Other change:
- Jam 1 (Cover open) occurs frequently in the bridge unit. Please refer to RTB#RB230-072 for more details.
- When the machine is in the paper end condition during limitless feed mode, the machine does the next job faster than the previous job.
Symptom corrected:
Under the following conditions, the final page or the pages near the end of the 1st copy are stapled into the 2nd copy.
- The customer sets "Staple" on the printer driver and makes two or more copies.
- Paper end occurs on the final page or near the end of the 1st copy.
V1.16:01
Other changes:
The detection timing of ADF errors was changed to reduce unnecessary occurrences of SC620.
V1.15:01
Symptom corrected:
If a finisher jam occurs during the stapling of a network printing job, Jam 17 will be triggered once the job resumes (during recovery printing).
V1.14:01
Symptom corrected:
Minor bug corrections.
V1.131:01
Other changes:
The parameters for white level adjustment were optimized to prevent unnecessary occurrences of SC142 (white level detection error).
V1.12:01
Other changes:
Supports the D042 model.
important: To apply this change, install all of the following firmware:
- System_Copy firmware ver 1.64 or later
- Engine firmware ver 1.12:01 or later
V1.11:01
Symptom corrected:
- The PM yield setting is not at the default value (refer to RTB #RB230020 for details).
- The machine might stall during a duplex job under the following conditions:
- The job is sent from the EFI controller
- The operator uses an external charge device with an decrementing counter.
- Light image density or white bands occur (the laser optics shutter does not open correctly).
V1.10:01
Other changes:
Improved the image quality in halftone areas printed out with the TWAIN driver and EFI controller.
V1.09:01
Other changes:
The occurrence conditions for SC300/301/302/303 (AC charge error) were optimized.
1.081:01
Symptom corrected:
- The machine may keep running if an interval process control self-check is done during a job that uses different engine speeds.
- Other minor changes were made to improve reliability.
Other changes:
- The settings of the following SP modes were changed for China models only:
- SP7-952-002: from 133703000 to 66852000
- SP7-952-003: from 162112000 to 81056000
- SP7-952-004: from 200554000 to 133703000
- SP7-952-012: from 160000 to 80000
- SP7-952-013: from 160000 to 80000
- SP7-952-014: from 240000 to 160000
1.07:01
Other changes:
1. Software changed to support the Korea model.
2. The default setting for Sp7-952-001 was changed to 300831000.
3. The default setting for Sp7-952-011 was changed to 360000.
4. Process control was changed to decrease the waiting time and increase the accuracy of toner concentration calculation.
1.05:01
1st Mass production
