Infotec ISC824 - 12320 Error
  • delands
    • Jun 2025
    [Error Code] Infotec ISC824 - 12320 Error
    Hi,
    I am looking for some assistance in fixing an error I receive whilst trying to scan using an Infotec ISC824.
    I am using the following from a Windows XP computer:
    DesktopBinder v5 Lite
    TWAIN v3
    (both downloaded from Ricoh website)
    In DesktopBinder TWAIN is showing as Type 1232 Scanner 3.7900 (32-32)
    When trying to scan, it shows : Searching then 12320 : cannot find the scanner
    Check if the scanner main power is on
    then
    Opening of the [Browse for TWAIN Driver] dialog box has failed (301-231)
    I have read that this may be due to firewall issues but I have disabled Kapersky and still receive the same error.
    The Infotec is not connected through a router but direct through the parallel cable.
    Finally, unsure if there is a connection however, the PC has an yellow exclamation showing that the SM Bus Controller is not working in Device Manager.
    I will be picking problem back up in the next few weeks so any assistance/ tips/ guidance would be grateful for my return.
    Many thanks in advance.
    David.
  • Eric1968
    • 2458
    Re: Infotec ISC824 - 12320 Error
    You can't scan using a parallel cable. This machine can do Network Twain scanning, scan-to-email, and scan-to-folder (with the use of the Scan Router program).
    • delands
      Thanks for the information so far!
      Does that mean DesktopBinder is not required but in fact, I should be using the Scan Router program instead?
      Am not at the PC/ Scanner to check what is installed/ configured presently.
      • Eric1968
        • 2458
        The most simple way is using network twain, or scan to email. Scan Router is not supported anymore by Ricoh and can give issues with firewalls and anti-virus software.
        • delands
          Many thanks Eric.
          I noticed that Ricoh still has ScanRouter to download.. what program(s) allow Network Twain or Scan to Email as you suggested?
          • Eric1968
            • 2458
            You can still download ScanRouter, but there's no support for it.
            The Network Guide (available for download at www.ricoh-support.com) explains how to setup scan-to-email. There's no need for installing additional software when you use Scan-to-email. You need a networked machine and an SMTP-server that can forward the mail from the machine.
            For Twain scanning you can use something like PaperPort or some other scanprogram. Ricoh only supplies the driver.
            • delands
              Thanks again Eric? This is all useful information for my return and should aid to a quick fix!
