scan reducction 3245c-mpc2500
  • xordi69
    • Jun 2010
    • 200
    hi everybody
    when I scan , machine makes a reduction of the original,I tried it in two Ricoh machines, 3245c and mpc2500
    resolution 200
    text
    A4
    its the same in PDF and TIFF.
    every help will be apreciated
    reduction.pdf
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: scan reducction 3245c-mpc2500
    Same on DF and platen glass?
    Hit it.
    • xordi69
      • Jun 2010
      • 200
      yes,now i have tried with other machine and (3228c) and the same, i think could be a convesion trouble...
      • TonerMunkeh
        Professional Moron
        • 3865
        I would agree, PDF compression can be a bit troublesome. I take it the customer is measuring the scans to see if they match?
        Hit it.
        • xordi69
          • Jun 2010
          • 200
          yes, but i also have detected the problem in TIFF files,and in diferent machines and different computers..everytime scanning to folder to XP, i will try now to W7...
          • xordi69
            • Jun 2010
            • 200
            no luck
            • TonerMunkeh
              Professional Moron
              • 3865
              no luck
              Is the same shrinkage apparent on copies doc server output?
              Hit it.
              • xordi69
                • Jun 2010
                • 200
                whith doc server no problem, and firmware updated
                • xordi69
                  • Jun 2010
                  • 200
                  sp 6017 to -0.5. better, but not perfect.
                  • Jomama46
                    • 2900
                    I have seen this before and unfortunately there is nothing you can do about it. As I remember it is compression problem. Doesnt bother most people but there is always the picky ones.
                    sigpic
                    A+; Network +; PDI+
                    • Gift
                      • Mar 2011
                      • 2459
                      I tell the customers that acrobat and most other programs includes a certain print margin - end of discussion ....I actually think it's not necessarily a lie.
                      Edit: If I try and print a PDF (picked a SM) I can see a margin in the preview of adobe reader
                      • xordi69
                        • Jun 2010
                        • 200
                        yes, but also happens to tif ... 6017 sp makeup the ruling, but shit, so difficult is to solve that? maybe firmware upgrade
                        thank you all for your interest
                        • Gift
                          • Mar 2011
                          • 2459
                          You can try scanning a ruler with a certain DPI setting, then loading it into a image editing software and see if the dots per inch setting of the machine fits to the ruler (better check the distance/pixel count over a few inch to get more exactly results). You can use irfanview (freeware) to select/mark an area of the image and get the resolution of your selcted displayed instantly.
                          • Jomama46
                            • 2900
                            That sounds like a lot of work with no solution. I like your first suggestion better. i.e. "Thats the way it is, get used to it"
                            sigpic
                            A+; Network +; PDI+
                            • Gift
                              • Mar 2011
                              • 2459
                              Figuring this out is a matter of a minute or two - the answere of the results will either proof that the machine does nothing wrong (something we can actually demonstrate to the customer) OR there is indeed some non-minor change of scale made by the machine (then we better have to stick with what we've told so far^^). I'll check it after the weekend - I don't have a ricoh at home yet^^
