ricoh 1045 bizzare:here is another one I need to fix.
  • nmfaxman
    • 1702
    Ricoh 1045 12200K. Print is crisp and clear. Incoming faxes clear and fine.
    Copies after 100 tend to repeat the random scan lines (like thread thin lines) 30 to 40mm towards th rear edge. I can print a counter list and it looks fine. If I copy that same print I have loss of density in the arrow with that loss of density moved up in a grey scale of 50%.
    The next image doubles the loss and increses the greyscale lines.
    I am replacing the whole scanner unit after replacing the controller, BICU, power supply, IO board and ccd board.
    If this doesn't work I have a problem.
    Has anyone else run into this problem?
    • 22936
    I think I would have tried doing a scanner focus adjustment. A lot of the newer scanners are not really designed in a way that's easy to adjust, but it can be done.
    Any old timers out there will remember snapped scanner wire ropes, or just frayed stretched cables. Newer scanners are smaller, lighter, and have less cable tension.
    Since you've already ordered the scanner, what can it hurt?
    Where Light Source #1 (the one with the exposure lamp) clamps to the cable, mark the cable with a Sharpie so you can find the original position if you need to. Loosen the clamps and move light source a millimeter or so to find the direction that improves your focus (it's a hit & miss sort of adjustment). Keep your adjustmants small! Adjust both front & back cable clamps for best focus.
    I haven't looked at an AF1045 in a long time, so I can't recall exactly what this scanner looks like. I'm sure this is covered in the service manual.
    • JustManuals
      • Jan 2006
      • 9838
      Did someone mention the service manual? Yes, I have it on my site at
      http://www.justmanuals.com
      I have a FREE text file of Ricoh-Lanier error codes on my other site at:
      http://www.manuals4you.com/weekly/Ricoh-Lanier Error Codes.pdf
      Paul@justmanuals.com
      • nmfaxman
        • 1702
        I replaced the whole scanner and readjusted.
        It turned out to be the ribbon conector to the laser unit.
        Printing was set @ 400 DPI. Copier was set @ 600 DPI.
        Two different adjustments and control signals.
        Machine fixed but a wierd problem.
