SC 320 in DSM 415pf
  • worksmart
    • May 2010
    • 16
    [Error Code] SC 320 in DSM 415pf
    Hello friends,
    This is the problem facing with DSM 415pf,
    Service Code Error SC320.
    Its a polygon motor rotation error, Replaced Complete Unit, still the same.
    Connectors, Cables all ok.
    Regards To All.
  • sandmanmac
    • 3980
    Re: SC 320 in DSM 415pf
    Next step is the BICU if connectors are good, and another unit gives same result
    • worksmart
      • May 2010
      • 16
      I replaced the BICU. The machine was ready now. But when I tried to copy the test page it resulted in paper jammimg in the fusing and then again the error code appeared SC 320.
      • ronald2020
        • May 2009
        • 31
        Hi worksmart,
        Did you manage to solve your problem? thought I would chip in with my 2cents can't exactly remember though if this directly affects this model but I do remember this range tends to throw that error if you forget to refit the toner bottle supply unit.
        all the best.
        • sandmanmac
          • 3980
          Originally posted by ronald2020
          Hi worksmart,
          all the best.
          Good call! That's got me a couple of times myself......pop in a new laser unit, covers still off for testing (toner hopper sitting on the table) and it pops the SC (either 320 or 322?) , and I'm there scratching my head for 20 minutes until I realize my stupidity
          • PinevskiS
            • Jul 2009
            • 283
            Change the Drum Unit.
