Ricoh Aficio 1075 SC 322
  • copy.eva
    • Jun 2012
    • 33
    What is SC322?
  • kyrenecopy
    • Apr 2012
    • 205
    Re: Ricoh Aficio 1075 SC 322
    laser sync detection error 322 D detector error
    After the polygon motor reachesstandard rotation speed and the LDunit fires for 500 ms, the lasersynchronization detector does notgenerate a signal.
    Harness between detector and I/F
    disconnected or damaged
    Detector is installed incorrectly.
    Detector board is defective
    Controller board defective
    IPU board defective
    LDB defective
    Testing 1-2-3, testing, testing. Is this thing on?
    • rsyarcia
      Hair Straightener Tech
      • 711
      also check the switches..
      Nobody is perfect..
      • kyrenecopy
        • Apr 2012
        • 205
        SC 322 [SC322 laser synchronization detector error] - make sure CN344 on IPU PCB pluged in correctly (bad connection)
        SC 322 [SC322] - make sure CN344 on IPU PCB pluged in correctly (bad connection)
        SC 322 Laser synchronization detector error - Make sure CN344 on IPU PCB pluged in correctly (bad connection)
        SC 322 Laser synchronization detector error - Replace laser diode PCB
        SC 322 Laser synchronization detector error - Replace laser sync detect PCB
        SC 322 Laser synchronization detector error - Replaced front door safety switch
        SC 322 Replaced front door safety switch
        SC 322 laser synchronization detector error [SC322 laser synchronization detector error] - make sure CN344 on IPU PCB pluged in correctly (bad connection)
        • Star
          Ricoh Tech
          • 127
          First things first, clean the detector. They can get dirty, either from dust or toner.
          • vargue
            • Oct 2011
            • 404
            first it's laser problem.but in big machine 1060/2060/1085/2090 always be switches threat check out switches.and clean it. or replace
            • copy.eva
              • Jun 2012
              • 33
              I have changed the detector, but I still have this problem...Interesting, I've copied above 300 blanco sheets through the ADF but the SC322 code does not appear, and when I put sheets with text then the code appears...P.S. What switches should I check?
              • rsyarcia
                • 711
                try the front and side doors switches.
                Nobody is perfect..
