Ricoh mpc 4500 not printing....
  • pukiro
    • Feb 2011
    • 59
    HI GUYS
    I have a mpc 4500 and the damn machine isn't printing, ping from pc is ok... scan to folder - no problems!
    but when sending a print job is fails....
    all firmware is up to date
    help!
    thanks
  • mikedci
    • Jul 2010
    • 227
    Re: Ricoh mpc 4500 not printing....
    anything in the printer error log on the mfp?
    user codes?
    • CSI
      • Oct 2008
      • 73
      Hi,
      Look at the answer of "Choro1dal" in this post :
      http://www.copytechnet.com/forums/co...question.html#
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
        • Llama God
          • Mar 2009
          • 1353
          Does the data light flash once when you send the job to it?
          • pukiro
            • Feb 2011
            • 59
            nope nothing, just an error in the printer icon
            • bryand
              • Jul 2008
              • 92
              sounds like there is a print job stuck in the que backing everything up.
              • fritzyas
                • Jul 2011
                • 73
                download and reinstall the driver
                • Llama God
                  • Mar 2009
                  • 1353
                  Are you sure that you haven't had any finger trouble at all, with the port for example?
                  Does it print from other PCs?
                  Is it printing via a server?
                  Can you print directly from a PC?
                  And so on...
                  • tcs04
                    FORMER Techie
                    • 1183
                    you have tried pinging the ip with this machine disconnected?
                    • Tonerbomb
                      AutoMajical Resolutionist
                      • Feb 2005
                      • 2589
                      lets start with the basics. 1 do you have happy lights on the nic, amber and green ?? if this machine has the gigabit nic you won't see green unless you on a gigabit network. 2 is sp5985 set to 1, not 0? Zero dis ables the nic, 1 is fully functional,2 is print only. Now take the network out of the equation and connect your laptop via crossover cable and setup your print driver to print to the machine. If print fails after all this you have a machine issue, if printing works this way your customer has an IT issue for thier IT dept. Hopfully your not thier IT dept. IF thier useing user codes to restict print and you don't have a code in the driver the data light will flash 1 time and not print.
                      Mystic Crystal Revelations
                      • pukiro
                        • Feb 2011
                        • 59
                        hi
                        first of all the green and amber are on, scan to folder is working fine... i can ping the machine from the pc and ping back to the pc from the machine, the nic is on "1"
                        but when i send a print job is says "printer:error"
                        ive deleted and reinstalled driver and still no luck...
                        any ideas?
                        thanks
                        • sandmanmac
                          • 3990
                          Originally posted by pukiro
                          hi first of all the green and amber are on, scan to folder is working fine... i can ping the machine from the pc and ping back to the pc from the machine, the nic is on "1" but when i send a print job is says "printer:error" ive deleted and reinstalled driver and still no luck... any ideas? thanks
                          I assume you can log into the WIM? If so, then Sometime ago I remember a post about this issue, and the solution was that under 'network security', DIPRINT and/or LPR had gotten disabled (by a client that refused to admit it). This DOES produce the non-print issue you describe, while scanning, etc, still function properly. Basically the defaults in this section are that everything except "bonjour" should be "enabled". good luck
                          • pukiro
                            • Feb 2011
                            • 59
                            hi thanks for the reply...
                            the funny thing is cannot even log into the wim... just comes up with HTTP 403 Forbidden...
                            ive switched on the telnet via command prompt etc, but no luck
                            • sandmanmac
                              • 3990
                              WIM Not accessible?
                              - Make sure SP5-828-091 is "1" (ON)
                              Also..
                              - User tools / System settings / interface settings / permit ssl/tls communication/ set to "clear txt/cyphertext
