MPC 3500 FAX
  • mikadonovan
    • May 2008
    • 2931
    MPC 3500 FAX
    When I log into the WIM and check the address book fax destinations, there is no "9" before the number. When I look at the machine op panel fax destinations, there IS a "9" before the number. I want to get rid of the "9". Is it a bit switch setting? I am having trouble finding it, and I would rather not have to reprogram a million fax numbers if I don't have to.
    NEVER ASSUME ANYTHING
  • nmfaxman
    • 1702
    Re: MPC 3500 FAX
    I think it is a user function to set for PBX systems to dial a 9 for outside line.
    • Llama God
      • Mar 2009
      • 1353
      Re: MPC 3500 FAX
      I think so too.
      • nmfaxman
        • 1702
        Re: MPC 3500 FAX
        PABX system.
        Check fax sp3103.
        Page 52 in fax service manual.
        • KenB
          Geek Extraordinaire
          • Dec 2007
          • 3944
          Re: MPC 3500 FAX
          It's SP-3103-002, to be exacct.
          Please check out the attached image from the service manual:
          • mikadonovan
            • May 2008
            • 2931
            Re: MPC 3500 FAX
            Thanks for the replies, changes to that sp didn't work for me. I bucked up and just dropped the 9 from the address book entries at the machine panel. Once I got into the rhythm it moved right along. Took me less than an hour.
