Cyan lines MPC 7501
  • Scooper123
    • Aug 2012
    • 6
    [CQ] Cyan lines MPC 7501
    Hi guys i have a problem with a mpc 7501, im getting faint cyan lines along the page i have replaced the charge roller but still the same, i have tried to attatch a demo but the scanner hasnt really picked it up ive marked where the lines are, it only happens on colour, and only cyan, ive checked the drum and mag roller no marks cant see anything out of the ordinary.
    Thanks in advance
  • waimun
    Re: Cyan lines MPC 7501
    Hi there,
    I'm not sure if this would help but I did experience the similar problem when i was on mpc6501. I did tackle the pcu side but to no avail. Until i did a thorough service on the whole machine and I found there were plenty toner spill on the ITB side. Did a complete clean up that area too and problem
    solved. Anyway, hope this will help.
    • Scooper123
      • Aug 2012
      • 6
      Originally posted by waimun
      Hi there, I'm not sure if this would help but I did experience the similar problem when i was on mpc6501. I did tackle the pcu side but to no avail. Until i did a thorough service on the whole machine and I found there were plenty toner spill on the ITB side. Did a complete clean up that area too and problemsolved. Anyway, hope this will help.
      I'm back there with a pcu tomorrow ill give machine a good service and clean the transfer its a touchy customer so want the pcu just incase it doesn't work but thanks for the advise Ill keep you updated
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
        • Llama God
          • Mar 2009
          • 1353
          Or I'll send you the manual for free.
          • turbojetboy
            • Aug 2009
            • 279
            Thanks in advance
            With that sort of colour volume you will have needed to replace those PCU's many times, the cyan always seems to go first - shortly followed by the others. Looks to me like the blades are starting to let go - but I only replace the entire units on these machines as the PCU's are flakey at the best of times.
            • Bantams
              • Jun 2012
              • 603
              Drum cleaning section needs a overhaul and best change the developer also service manual for the Venus is here Documents
              • Scooper123
                • Aug 2012
                • 6
                Thanks for all the suggestions.
                Stripped the belt and cleaned today and its working all ok, the units have only done about 40k, ive got some spare blades and charge so ill replace those in the next few days. customer is happy for now well until it starts leaking toner again.
                Thanks again
                • Llama God
                  • Mar 2009
                  • 1353
                  Thanks again
                  If it's leaking toner, check this out...
                  MPc6000.rar
