mpc3500 fuser exit jams
  • banginbishop
    grumpy old git
    • Oct 2007
    • 894
    mpc3500 colour 1.1m b 600k so no spring chicken!
    bridge unit and finisher
    oem toner
    all items well within pm life
    customer hasnt complained about it but i noticed it when i replaced a drum when checking the machine over.
    3 power on jams - not concerned
    25 in fuser exit - replaced all exit rollers about a month ago.
    any ideas?
    Incontinentia Buttocks
  • HappyHarry
    • Jul 2011
    • 7
    Re: mpc3500 fuser exit jams
    Strip out exit again, clean all shaft bushings and lub.
    • banginbishop
      grumpy old git
      • Oct 2007
      • 894
      would do if i was a lazy engineer should ALWAYS do that anyway when taking out a shaft or replacing one.
      • Vioksrall
        • Sep 2010
        • 84
        Lubricate bushings at exit unit.
        • banginbishop
          grumpy old git
          • Oct 2007
          • 894
          ok I give up
          • Vioksrall
            • Sep 2010
            • 84
            if you're that lazy, you don't need to pull it out. just shower it with WD-40. Enjoy!
            • banginbishop
              grumpy old git
              • Oct 2007
              • 894
              do yourself a favour and read the post properly then comment with a worthwhile reply! untill then i'll wait for someone who can possibly give some HELPFULL guidence.
              • spaceman99
                • Jul 2009
                • 174
                Power on jams = two sensor in the brige unit need replacing as well as updating the firmware.
                Try tappimg the bridge unit and you should see the alarm light come on/off
                Re exit jams = clean the separator bar on the fuser belt and change the bearings. Also lubricate the bushings at exit unit. The nylon drive gear fails.
                good luck
                • banginbishop
                  grumpy old git
                  • Oct 2007
                  • 894
                  nylon drive gear?
                  bad pic item 18?
                  • gaudin
                    • Mar 2008
                    • 39
                    Check out this part of the exit unit...and lub everything
                    As you see on the 2.pic...guide plate was deformed.
                    Its from mpc3300...but i think its similar.
                    Certified for:
                    Compita A+ / N+ / S+
                    Microsoft MCST / MCA
                    • CableGuy
                      Impulse Drive Engineer
                      • Oct 2008
                      • 417
                      Hi
                      I had a headache on a mpc5501, exit jams and turning the front corner on a random basis. I could not see a damned thing wrong in the exit unit, ended up replacing the entire unit. I'm waiting to get one of these machines in the shop so I can try the old unit out on it to see if I can find the fault... Hate being beaten by a machine!!
                      Out of interest, what jam code is the machine calling up?
                      Cheers
                      • Llama God
                        • Mar 2009
                        • 1353
                        Suck eggs like this...
                        Have you got a decent lead edge registration set? They may be doing thick colour when you're not looking.
                        Are the rollers on the fuser guide that transport to the duplex unit seated correctly?
                        Are the rollers in the exit unit turning freely? The do seize intermittently.
                        Finally, the cover sensors in the bridge unit for the power on jams.
                        Other than that, I have nowt.
                        • S.Bradley
                          • Mar 2012
                          • 14
                          oem toner
                          any ideas?
                          Have you had it jam whilst you have been testing the machine so you can see where the paper is jamming? I have had two customers with MPC 3500's with fuser exit jamming in both cases the lead edge of the print was going under the stripper bar. This only seemed to happen intermittently perhaps one in 500 prints & only on high coverage prints. I found that in both cases that the stripper bar was not sitting flush with the fuser belt. On one customer I managed to get away with just changing the stripper bar, the other customer ended up being a complete fuser rebuild in the end so I'm guessing it may have been the Hot roller wearing. Both customers fusers where @ around 75% life. Maybe worth looking at if you have not done so already.
                          • mikadonovan
                            • May 2008
                            • 2931
                            I know you said PM items were well within their range. I had a fuser misfeed issue on this model a while back, and it ended up being the paper transfer roller assembly. The plastic coating was worn off around the metal fingers causing the paper to catch on it sometimes.
                            NEVER ASSUME ANYTHING
                            • banginbishop
                              grumpy old git
                              • Oct 2007
                              • 894
                              Havent been there for a bit so havent had a chance to look at it. Its not jammed when im there, power on jams are a lot lower now (bridge unit switches been replaced a few months ago). I am tempted to replace the whole exit section if needed. Fuser never gets rebuilt anymore I just stick a printer version on. If or when I get a chance to look at it I'll report back and thanks for the replies.
