mpc3500 fuser exit jams
  • Bantams
    • Jun 2012
    • 603
    #16
    Re: mpc3500 fuser exit jams
    Those power on Jams are a Firmware Issue the switches in the Bridge unit were too Sensitive the firmware was updated to fix it.
    It could also be causing the Fuser exit Jams if one of the sensors suddenly detects a Cover open it will Jam
    • banginbishop
      grumpy old git
      • Oct 2007
      • 894
      #17
      I knew about the switches some time ago but not about the firmware fix - cheers
      Incontinentia Buttocks
      • digicor
        • Jul 2008
        • 1153
        #18
        Originally posted by Vioksrall
        if you're that lazy, you don't need to pull it out. just shower it with WD-40. Enjoy!
        hahahahahahah i have to laugh out loud !!!
        is it making chineese fans or just stopping mid stream lika a bad prostate....LOL
        • digicor
          • Jul 2008
          • 1153
          #19
          i had this problem as well, i just taped the damm thing down with scotch tape.. problem solved
          • banginbishop
            grumpy old git
            • Oct 2007
            • 894
            #20
            dont know, never seen it jam when i've been there. customer doesnt complain about it but as its shows a high jam rate in 1 section then im a bit concerned about it.
            holy shit - no disrespect but thank f**k you dont work with me. its a safety switch to stop dumb ass customers sticking the finger in there while its running. yeah you aint gona do much damage but I could get sacked for doing that and i'd report you for it if I found it - sorry just not the thing i'd do.
