Re: mpc3500 fuser exit jams
dont know, never seen it jam when i've been there. customer doesnt complain about it but as its shows a high jam rate in 1 section then im a bit concerned about it.
holy shit - no disrespect but thank f**k you dont work with me. its a safety switch to stop dumb ass customers sticking the finger in there while its running. yeah you aint gona do much damage but I could get sacked for doing that and i'd report you for it if I found it - sorry just not the thing i'd do.
i had this problem as well, i just taped the damm thing down with scotch tape.. problem solvedLeave a comment:
I knew about the switches some time ago but not about the firmware fix - cheersLeave a comment:
Those power on Jams are a Firmware Issue the switches in the Bridge unit were too Sensitive the firmware was updated to fix it.
It could also be causing the Fuser exit Jams if one of the sensors suddenly detects a Cover open it will JamLeave a comment:
Havent been there for a bit so havent had a chance to look at it. Its not jammed when im there, power on jams are a lot lower now (bridge unit switches been replaced a few months ago). I am tempted to replace the whole exit section if needed. Fuser never gets rebuilt anymore I just stick a printer version on. If or when I get a chance to look at it I'll report back and thanks for the replies.Leave a comment:
I know you said PM items were well within their range. I had a fuser misfeed issue on this model a while back, and it ended up being the paper transfer roller assembly. The plastic coating was worn off around the metal fingers causing the paper to catch on it sometimes.Leave a comment:
mpc3500 colour 1.1m b 600k so no spring chicken!
bridge unit and finisher
oem toner
all items well within pm life
customer hasnt complained about it but i noticed it when i replaced a drum when checking the machine over.
3 power on jams - not concerned
25 in fuser exit - replaced all exit rollers about a month ago.
any ideas?Leave a comment:
Suck eggs like this...
Have you got a decent lead edge registration set? They may be doing thick colour when you're not looking.
Are the rollers on the fuser guide that transport to the duplex unit seated correctly?
Are the rollers in the exit unit turning freely? The do seize intermittently.
Finally, the cover sensors in the bridge unit for the power on jams.
Other than that, I have nowt.Leave a comment:
Hi
I had a headache on a mpc5501, exit jams and turning the front corner on a random basis. I could not see a damned thing wrong in the exit unit, ended up replacing the entire unit. I'm waiting to get one of these machines in the shop so I can try the old unit out on it to see if I can find the fault... Hate being beaten by a machine!!
Out of interest, what jam code is the machine calling up?
CheersLeave a comment:
Check out this part of the exit unit...and lub everything
As you see on the 2.pic...guide plate was deformed.
Its from mpc3300...but i think its similar.
2.jpgIMG00109-20110822-1302.jpgLeave a comment:
Power on jams = two sensor in the brige unit need replacing as well as updating the firmware.
Try tappimg the bridge unit and you should see the alarm light come on/off
Re exit jams = clean the separator bar on the fuser belt and change the bearings. Also lubricate the bushings at exit unit. The nylon drive gear fails.
good luckLeave a comment:
do yourself a favour and read the post properly then comment with a worthwhile reply! untill then i'll wait for someone who can possibly give some HELPFULL guidence.Leave a comment:
if you're that lazy, you don't need to pull it out. just shower it with WD-40. Enjoy!Leave a comment:
