AF2020D
  • +ve charge
    • May 2008
    • 87
    [Jamming] AF2020D
    Hi to all of you! Pls help me out with this problem i'm encountering. Paper feeds upto the entrance of the fusing unit and jams. The rest of the paper is curled up beyond the registration. (feeding A4 portrait/lengthwise). The Fusing Unit H/R, P/R and P/R bushes seem ok. The problem escalated progressively (from intermittent jams to jamming every copy). Yr comments appreciated. thanks & have a nice day/night.
  • BLADE
    former propeller tester
    • 478
    Re: AF2020D
    the transfer roller gear might be worn
    • +ve charge
      • May 2008
      • 87
      Re: AF2020D
      Thanks for yr response. It's not the Transfer Gear. The paper passes that point.
      • Bantams
        • Jun 2012
        • 603
        Re: AF2020D
        Does it jam when feeding A4 Landscape?
        Are the Fuser rollers rotating?
        • Masterchief
          • Apr 2011
          • 280
          Re: AF2020D
          Before the paper start jamming constantly, did you print of the smc report log data sheet. If you got to service mode now wher does it indicate last jam number and then refer back to the service manual, this will give you a heads up and if you can provide more informaton on this then we can help more
          sigpic
          • JustManuals
            • Jan 2006
            • 9838
            Re: AF2020D
            Paul@justmanuals.com
            • femaster
              • May 2011
              • 1526
              Re: AF2020D
              Based on the little information you have provided, I'd say that 1) the fusing rollers are not turning, 2) the entrance plate to the fuser is broken some how, or 3) the drum shutter gear has slipped from people slamming the door shut, and does not fully open, snagging the paper.
              If I had more information I might change my predictions some, but those are the things I'd check first based on the provided knowledge.
              • +ve charge
                • May 2008
                • 87
                Re: AF2020D
                Oh Wow!! Yr right! The Fuser Roller is not turning??!! Live and learn. Will be looking into this matter now. Meanwhile any advice will be greatly appreciated. Thank You!
                • josueol1
                  Re: AF2020D
                  can be a problem fusion AE04 4062 Stripper Pawl or in separation drumB039 2335 Pickoff Pawl
