3224C Overheating without error code
  • mrwho
    Major Asshole!
    • 4299
    [Misc] 3224C Overheating without error code
    Mascan42
    Ibid
  • Bantams
    • Jun 2012
    • 603
    Re: 3224C Overheating without error code
    It Could be that the cooling fan isn't working it's located behind a small grill towards the rear of the left hand cover near the fuser door.
    • tcs04
      FORMER Techie
      • 1183
      (Stating the obvious?)... If the thermistors are bent / dirty, they will register a lower temperature than the actual temp and the machine will run hot.... until the thermostats blow!... (Smack them against the wall if they do.. ! )
      • femaster
        • May 2011
        • 1504
        I believe there is also a cheap washable "filter" under the cover for that fan also. If the copier is in a dirty environment, it could be plugged.
        • Masterchief
          • Apr 2011
          • 280
          My answer would be the same, common problem with overheating in some models.
          sigpic
