Lanier LD425c (b230) firmware failure
  • tonerhead
    • Sep 2009
    • 582
    Was doing a firmware update. While machine was updating when a message of bad firmware download appeared on display. I powercycled machine and now it will not come out of "please wait" on display at boot up. It also will not boot with SDcard. Any thoughts or did I make a "brick" of the controller by updating firmware with sd card? Any help appreciated.
    I've proved mathematics wrong. 1 + 1 doesn't always equal 2.........
    Especially when it comes to sex
  • Herrmann
    • Jan 2006
    • 792
    Re: Lanier LD425c (b230) firmware failure
    which part of firmware did you try to update?
    you can only force system to boot up from sd card, all other will fail. if the error occurs on engine update, you will be in need to replace bicu board
    If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
    • tonerhead
      • Sep 2009
      • 582
      The engine and system firmware updated normally. I think it was in the middle of the fax firmware update when it cacked on me
      • femaster
        • May 2011
        • 1527
        What was the error number? According to the service manual, if there is an error, it will show the letter "E" followed by a 2-digit number, indicating what the problem was...
        5.6.9 HANDLING FIRMWARE UPDATE ERRORS Error Message Table
        • Herrmann
          • Jan 2006
          • 792
          ok, in this case disconnect the fax assy, does the mashine fire up?
          • tonerhead
            • Sep 2009
            • 582
            I powercycled too soon before checking for e-code. That is part of my plan to remove fax, hdd, etc and hopefully it will come back to life. I have had one in the past that was stuck on please wait and had to replace NVRam. I suppose the same might happen here. I have also heard somewhere of someone shorting pins on NVram to reset, wonder if that works?
            • Tonerbomb
              AutoMajical Resolutionist
              • Feb 2005
              • 2589
              I wouold refer to the manual about the procedure to boot from the SD card, asI know on several of the Ricoh boxes you have to set a dip switch on the controller to boot from the SD card. Also E codes usually have to be cleared through the Factory sp mode. You can find referance on how to acesss this mode in many other posts.
              Mystic Crystal Revelations
              • femaster
                • May 2011
                • 1527
                In case you don't have the manual available:
                5.10 DIP SWITCHES
                5.10.1 CONTROLLER BOARD
                DIP SW No. OFF ON
                1 Boot-up from Flash Memory Boot-up from SD card
                2 to 8 Factory Use Only: Do not change the switch settings.
                • tonerhead
                  • Sep 2009
                  • 582
                  Re: Lanier LD425c (b230) firmware failure (fixed)
                  Thanks to those who replied. The solution however came from Goose's Guide. It appears on firmware failure that you can do clear modes,1,4,3, stop(3x) and turn off power. This resets the firmware to previous versions before failure. I corrected corrupt file on card and powered back up. Firmware loaded normally.
