ricoh - background on copies
  • vaclav borc
    • Jan 2008
    • 75
    I need once and forever find out how to get off backgroud on copies,
    specialy with Ricoh aficio copiers.
    Just now i have Ricoh aficio 200, PCU have made 25K kopies .
    I cleaned charge corona, contacts , used grafit paste on contacts.
    still is background.
    Please do not tell me to change drum or developer.I am sure it will not help.
    some simulations? dev. bias? primary charge? contacts?
  • _SuabE_
    • Jan 2008
    • 108
    Confusing There is a lot of things to be considered when resolving background on copies, What type of background? Snowy? darked spotted? even background or uneven? What are the effects on the image, light? or dark? or emboss? Are you using original toner or oem? did you try to adjust the toner bias to higher value? Give some more details so i can help you to configure it out.
    sigpic
    Senior Technician Specialist
    A+; Network+
    Copier Brand handled: Canon, Lanier, Konica Minolta, Sharp, Ricoh, Kyocera Mita, Nashuatech, Ollivetti, Toshiba
    Printer Handled: Canon, HP, Epson, Brother, Samsung
    Duplicators: Risograph, Duplo
    • iMind
      Vacuum Cleaning Expert
      • Mar 2008
      • 1116
      Aficio 200 PCU is a hole block insert new PCU and it will ajust by it self
      • vaclav borc
        • Jan 2008
        • 75
        every time i had alternative toner, but i still used this toner - no problem.
        i try to specific the problem : it is like fly ash,flue dust. /if you remeber
        minolta ep 1050 - when developer reached 150k copies and more/.
        Image in normal but there where have to be paper white is flue dust /not paper or another dust , but toner dust/.
        Once I had too strong background /aficio 1015/ - so it was transfered on
        lower transfer corona and after on back side of paper.I did not know what
        to do. I changed developer+initialized, changed drum,changed toner.
        Finaly i was told to cleane contact for upper corona and problem disappeared.
        i am sory about my english
        yes , it is snowy, what is toner bias ? is it developing bias?
        when i changed developing bias to be image darkest, the background appeared more
          • 23009
          I haven't seen one of these in ages. I thought they were obsolete 7 years ago?
          From Gooses Notes:
          1) Change these settings: SP2-999 to '0', SP2-996 to '120', SP2-994 to '10', SP2-911 to '2', & SP2-201 to '600'.
          2) Bad high voltage power supply board.
          3) Bad PCU (they're only good for 45k...).
          Are you sure this isn't over-toning? It was very common on these.
          • vaclav borc
            • Jan 2008
            • 75
            From Gooses Notes:
            sure ,not overtoned , but reversely
            1) these setting controls image density. I have not problem with image
            density.
            2) possibly, but given that it is not by far only one machine, i think not help
            3) I would like change PCU, but i worked only 25K
            it is possible accept these fact -
            1) the toner not original - developer is not able to retain this toner
            2) must by any magnetic or electric power, what have efect to retain toner retained the developer/Drum grund contact/.
            doesnt metter, some mystery , by the time i eplore the problem, i tell you.
            • mfag
              • 14
              If you are replace toner type with other(compatepel toner) you will see over tonering if it is
              you must caleprate density toner in developer after that make som calipration in toner sensor to be 2 +(-)10%
              • Cipher
                It's not easy being green
                • May 2006
                • 1309
                These models have gone the way of the dinosaur.
                I would suggest if customer is that bothered about the CQ that they part with some money and buy a new machine.
                • Lescort
                  Re: ricoh - background on copies
                  hello my friend, did you fix your aficio 200 machine?, it is something like the picture ?
                  in case of true, i resolved this problem definitively with true exit. without nothing new.
                  if need help yet, please reply me.
                  thanks for listen, Carlos, Cd Obregon Son, mx, copier technician
                  • Eric1968
                    • 2458
                    I hope for him that he resolved it because the original post is from 2008!!
                    • Lescort
