2035 print image density problem
  • cbr600
    • Jun 2010
    • 71
    The long edge of the text printed is not is not seeing verry well, symptom like a dirty laser but it isn't.
    I saw on developer roller at the back there is not enough developer on roller, i changed the develeper unit with a good one and after 50 prints the problem is back.
    If anyone can give me a clue will be great.
  • JustManuals
    • Jan 2006
    • 9838
    Re: 2035 print image density problem
    Paul@justmanuals.com
    • Butrus
      • Jan 2012
      • 115
      Did you clean the glass under toner ?
      • Jude
        • Oct 2009
        • 256
        Is the known good dev on the roller. You may have a bad power supply. Did you change just dv unit or entire unit?
        • cbr600
          • Jun 2010
          • 71
          I clean the glass from laser,the polygon motor, the mirrors.I changed only the developer unit and after that the drum too.
          • ccchuah
            • Mar 2009
            • 157
            Maybe the machine is not level and tilt to one side or the developer inside the tank is less than 500gms, hope this may help.
            • cbr600
              • Jun 2010
              • 71
              I changed the power board, same problem, the dev unit is from other machine wich is working perfectly.I will try to see if the machine is not staying straight but i'm sure that isn't the problem.Thx for ur replays.
              • Imprestik
                • Aug 2012
                • 297
                ID Sensor, if it's not getting a good reading off the drum ,it will give you density problems...
                Any SC codes in the back ground like SC350......
                • cbr600
                  • Jun 2010
                  • 71
                  First time if i remember was sc9x and 5x but i will look again.
                  • rthonpm
                    • Aug 2007
                    • 2859
                    Do you have a scan of the image you could attach?
                    Have you also looked at the transfer roller and paper?
                    • Bantams
                      • Jun 2012
                      • 603
                      Did somebody leave the plastic cap in the toner supply entrance hole on the PCU?
                      Yep I've done it myself too once or twice in the past
                      • nmfaxman
                        • 1702
                        Clean out the DV unit and clean the MAG roller.
                        Set the Doctor blade gap to a tight .35 MM.
                        Put in new developer and run the TD initialization and developer initialization.
                        Open the right cover and cheat the door.
                        Run a skyshot and stop the machine as you see the drum covered with toner.
                        If it is still light, check drum unit and charge erase lamps.
                        On these machines I always replace the drum, blade and DV at the same time.
                        More money in parts, but the machine runs cleaner and I rarely have a CQ problem.
                        • cbr600
                          • Jun 2010
                          • 71
                          U won't believe, the problem solved over night so far is working with no problems.
                          Things wich didn't solved the problem:
                          1. poly motor / mirorrs was cleaned
                          2. drum was changed
                          3. dev roler was cleaned / changed with entire dev unit
                          4. power supply was changed
                          5. no sc 3x.
                          6. the copier was standing straight.
                          • cbr600
                            • Jun 2010
                            • 71
                            • rthonpm
                              • Aug 2007
                              • 2859
                              How does the fuser look?
