8001 document server issue
  • mikadonovan
    • May 2008
    • 2931
    Hi. all, I have a customer that cant send a single file of 5600 pages to the doc server because its more than 5000 pages. I have tried changing the settings of system sp 5182 001 to allow expansion, did not work , I cant change 5182-002 at all. Any ideas on this one?
    NEVER ASSUME ANYTHING
  • femaster
    • May 2011
    • 1512
    Re: 8001 document server issue
    The size of the "document" seems a bit ridiculous; 5600 pages? I really don't know what to tell you with that one. It may also be a limitation of the actual file size itself, not just the number of pages.
    I'd say split the thing up into two different files and save the headache...
    • KenB
      Geek Extraordinaire
      • Dec 2007
      • 3944
      Hmmmm... The product support guide says only 2,000 pages per document.
      • Tonerbomb
        AutoMajical Resolutionist
        • Feb 2005
        • 2589
        [ATTACH=CONFIG]17862[/ATTACH]
        This has been the Ricoh limit for quite sometime...........
        Mystic Crystal Revelations
        • teebee1234
          • Jul 2008
          • 1670
          The best I could determine was 3000 pages/job max and 3000 jobs max (depends on various factors including coverage). Attached is the Printer bit switch chart that you may want to check out - look for Controller 08A GW in the first column. Looks like you can increase the maximum amount of stored pages from 10000 to 45000 pages (total) using Printer SP5-182-001. Not sure that it will improve the doc server capacity though.
          • teebee1234
            • Jul 2008
            • 1670
            Removed dup post
            • mikadonovan
              • May 2008
              • 2931
              Thanks a bunch for the info. I'll try that today.
              • mikadonovan
                • May 2008
                • 2931
                It's a utility company's billing packets, therefore a lot of pages per packet (largest is a little over 16K pages)
