Aficio 1515mf ADD TONER
  • mrfuser
    • 1621
    We replaced the entire PCU assembly and it still says ADD TONER, any thoughts?
    Kelly
  • Shadow
    PHD in Sh!t Disturbing
    • Sep 2011
    • 455
    Re: Aficio 1515mf ADD TONER
    remove the toner sled and disassemble it.
    look to see if the little mylar flippers have come off and blocked the outlet.
    have you power cycled the machine to reset everything?
    $hit Happens - Deal with it and move on.....................................sigpic....................................Lock & Load
    • sandmanmac
      • 3981
      Originally posted by mrfuser
      We replaced the entire PCU assembly and it still says ADD TONER, any thoughts?ThanksKelly
      ....I would refer to all the answers you got for the MP2000 "add toner" issue you had last week... except in this case you've not stated that the bottle is actually turning, so it could be the toner clutch
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
        • nmfaxman
          • 1702
          Did you run TD setup, ID setup and DV initialization?
          This IU is not a 1027 PCU that sets itself up.
          Run a DV churn and then run TD Initial, then ID initial, then developer intitial.
          Reset the PM counter to know how old the IU is.
          • jonezy999
            just one copy??
            • Feb 2010
            • 952
            Sorry to sound like a dick here, but I have never ran any of those codes when replacing these PCu's.
            Even my field manual says the setup is automatic at power on.
            I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
            • Polarbear
              • Feb 2012
              • 1070
              I have to agree with jonezy999
              Check the underside of the pcu - if there are 2 silver plates on the bottom of the pcu on the same side as the pcu receptacle plug, then it will be setup the moment the machine powers up after installation.
              I know that some of these models (MP161/171 love doing this) go into a toner end "lock" if left in toner end condition for a few days.
              One then has to do toner end clear in sp mode or else it will not recover and start adding toner and go about its normal business.
              Press the GREEN button!!
              • Counsel
                • Aug 2011
                • 529
                Few things ive run into on these when add toner wont go away. 1st wrong toner bottle which usually makes a mess by the way. 2cd the clear cap is stuck in the hopper from the empty bottle. 3rd toner clutch fails you should be able to run toner clutch in output mode and verify the bottle is even rotating. 4th the mylar fins in the hopper broke off. 5th the shutter door is blocked/clogged/ or broken so toner isnt dropping into the dev unit.
                I have had these machines act as though an old bottle ran so dry that you have to open and shut the front door 2-3 times before it finally gets enough toner, but thats usually only in the case of a new bottle with the old pcu. With a new pcu change it should have done that at power on. Sounds like a hopper issue.
