ricoh aficio mp 1350
  • NEOTECH
    • Dec 2010
    • 69
    [Error Code] ricoh aficio mp 1350
    hi dear i have a problem for web roll reset how can i do this.
    thank's
  • sakura
    • 132
    Re: ricoh aficio mp 1350
    Use SP mode to reset it when a new web was installed. Usually SP1902 changed to 0 (zero) and a re-boot after helps to eliminate "cleaning web needs replacement" message.
    • fbkhan3
      • May 2012
      • 421
      ''1902'' ,Web used Area display, change value back to ''0''
      PM counter Reset for web Roll as well in SP 7''
      HTH!
      • Ollie1981
        Toner Monkey
        • Mar 2008
        • 417
        You have changed the web roll right? If the roll is still exhausted or you have put the replacement in incorrectly then the end sensor arm may still be In the "exhausted" position. If that's the case you can mess around with sps all day long and the message won't clear.
