envelope printing
  • digicor
    • Jul 2008
    • 1159
    envelope printing
    Im wondering how to get my mpc3500 to print odd size envelopes???
    i have 8 x 5 xmas cards and the envelopes will not print, from by pass , in the tray i have to use a5,still not centered
    how do i program the bypass in print?I will not accept my custom settings, even from web access,
    is there an override in the driver somewhere?
    by the way it copies the size just fine from the bypass???
    how do i unlock it to do the same for printing?
    thanks
  • totoro
    • 568
    Re: envelope printing
    Can you print to the document server and then print from the machine correctly?
    Totoro
    • Tonerbomb
      AutoMajical Resolutionist
      • Feb 2005
      • 2589
      when you setup the job are you using MS word or some other app?? Word will over ride your print driver settings. So if you go to printer properties and select bypass, custom size, ect and word page setup says page size says it's something else the job will use the settings from word. Setup the page size and type in word to match what you need in the print driver,aka custom size 8x5 short edge feed thick 1. DOn't call it an envelope just a custom size. If size andd type don't match the machine you'll get the red light to correct this. The machine should be set for PC control in printer features. DOn't complain when the envelope comes out with some wrinkles!!!
      And why do people always want to run a folded up glued together piece of paper through a mfp?.......
      Mystic Crystal Revelations
      • whitecat
        • Nov 2012
        • 43
        Can u use duplex ( print on both sides of paper) when printing?
        If u can copy on the odd size paper but cant print ,my guess is that u need to "play" with the settings from printer driver (preferences and properties)
        • KenB
          Geek Extraordinaire
          • Dec 2007
          • 3944
          Never a pleasant experience.
          The machine simply isn't designed for it.
          • Imprestik
            • Aug 2012
            • 297
            There is a envelope kit for these machines. It is designed for tray 2 only.
            I have a couple of clients with them and they work a charm. They do kill fusers though, only annoying thing.....
            • KenB
              Geek Extraordinaire
              • Dec 2007
              • 3944
              Nowhere in this thread is the model mentioned, unless I'm being silly and just missing it
              As an example, I looked in the product support guide for the MPC3500, and saw no mention of an envelope accessory for it.
              Perhaps it's only for certain models, and maybe not available in the US?
              • Debs1964
                • Oct 2010
                • 1693
                First post...MPC3500 :-)
                There are 10 types of people in this world, those who understand binary maths and those who don't
                • KenB
                  Geek Extraordinaire
                  • Dec 2007
                  • 3944
                  OK, thanks.
                  Guess I need new glasses after all.
                    • 23009
                    I haven't worked on Ricoh in a while but I suspect that if you select envelope media type, you will be limited to three or four standard envelope sizes. On the other hand, if you select thick paper (same heat setting), you may still be able to set a custom paper size. =^..^=
                    • Imprestik
                      • Aug 2012
                      • 297
                      Here in Australia there is definately a envelope feeder kit.
                      I will see if we have one in our demo room and take a picture of it
                      As for fusing, you actually want to bump the heat down as much as possible as it helps not sticking the glue tab to the envelope, also helps with creasing
