Toner black problem Mpc3000
  • Gesttech
    • Oct 2009
    • 123
    [Misc] Toner black problem Mpc3000
    Hi All
    My problem was on copier Mpc3000, the problem was the toner black.
    i put in a new toner k & PCU K but it cannot detect toner black.
    i try to reset the toner k on sp3045 it reset but when doing copy toner k indicator display & its block.
    What can cause that, the toner end sensor for black, BICU, pump toner black. Help Please.
    Thanks..........................
  • ucinn
    • Jun 2009
    • 383
    Re: Toner black problem Mpc3000
    Originally posted by Gesttech
    Hi All
    Everytime I've had this problem, it's been the toner pump.
    • Eric1968
      • 2458
      Replace the black toner pump. It's a common problem on these machines.
      • sandmanmac
        • 3979
        STFF! (search the F*****g forum !)
        • kannuki2
          • Feb 2012
          • 398
          we all need to take an anger management class on this question....
          • Dumus
            • Feb 2010
            • 79
            B223 3251 Pump unit BK assay (with hose) ......
            • stani
              • Jan 2013
              • 49
              the difference between the pumps for different colors is only the hose (that you really dont need) - so you can use the pump for any color. A had also another reason for "Toner empty" - the gear, that drives the development unit was worn
              • rtiql8n
                • Jul 2012
                • 14
                I have the same problem. Does not see the new toner bottle. Tried two different OEM toners too. Did a SP 3045 and ran a couple of copies. They look great. Turned the SP 3045 back on and rebooted. No toner comes right back. Vacuumed the entire toner delivery system, swapped pumps with the magenta pump (after cleaning them out), swapped the toner end sensors as well. No change. Any thoughts?
                  • 37393
                  Why did you swap the black and magenta pumps? Quite frequently the problem is the toner hose being clogged. The new pump includes the hose. I have never had any luck trying to clean the toner pumps. Try a new black toner pump assembly. Also check the nozzle assembly as those can clog. Bypass the front door interlock and check that the toner bottle rotates when you turn SP 5804-020, Toner Transport Motor, and SP 5804-100, toner supply motor clutch: K. If the bottle does not rotate, it is either the motor or the clutch. Test to see if the other bottles rotate, SP 5804-101 thru 103 for the clutches. If none of them rotate, the motor is bad.
                  • rtiql8n
                    • Jul 2012
                    • 14
                    I swapped pumps to see if it was a pump problem. After I swapped them I checked for toner delivery in the DV units. Both pumps that I swapped are working fine. All bottles rotate fine as well.
                      • 37393
                      Then you most likely have a clogged or pinched hose. There are a couple of bulletins concerning pinched hoses and what to do to prevent them.
                      • rtiql8n
                        • Jul 2012
                        • 14
                        But I am getting toner to the DV unit.
                        • rtiql8n
                          • Jul 2012
                          • 14
                          So this morning, I did a sp3045, calibrated the copier and exited the sp3045. Rebooted the copier and I now have a happy copier properly displaying all of it's flavors! No idea why but, I'm going to run with it. Thanks for your help everyone.
                          • mbolduc
                            • Jun 2015
                            • 53
                            A flaky RFID board can cause the same symptoms...
                            • impetus73
                              • Mar 2012
                              • 75
                              Swapped a pump with a used one with another colored toner inside of it? Are you crazy? :-0
