Ricoh Aficio 2045e reset factory - how?
  • steve02a
    • 16
    #16
    Re: Ricoh Aficio 2045e reset factory - how?
    Well, now FTPisn't working.
    I have filezilla setup all properly. User and folder is in filezilla.
    here is what filezilla logs:
    Code:
    [SIZE=1](000008)12/21/2012 14:03:01 PM - (not logged in) (192.168.1.109)> Connected, sending welcome message...
    [/SIZE][SIZE=1][COLOR=#008000][SIZE=1][COLOR=#008000](000008)12/21/2012 14:03:01 PM - (not logged in) (192.168.1.109)> 220-FileZilla Server version 0.9.41 beta
    (000008)12/21/2012 14:03:01 PM - (not logged in) (192.168.1.109)> 220-written by Tim Kosse (Tim.Kosse@gmx.de)
    (000008)12/21/2012 14:03:01 PM - (not logged in) (192.168.1.109)> 220 Please visit http://sourceforge.net/projects/filezilla/
    [/COLOR][/SIZE][/COLOR][/SIZE][SIZE=1][COLOR=#000080][SIZE=1][COLOR=#000080](000008)12/21/2012 14:03:01 PM - (not logged in) (192.168.1.109)> USER sss
    [/COLOR][/SIZE][/COLOR][/SIZE][SIZE=1][COLOR=#008000][SIZE=1][COLOR=#008000](000008)12/21/2012 14:03:01 PM - (not logged in) (192.168.1.109)> 331 Password required for sss
    [/COLOR][/SIZE][/COLOR][/SIZE][SIZE=1][COLOR=#000080][SIZE=1][COLOR=#000080](000008)12/21/2012 14:03:01 PM - (not logged in) (192.168.1.109)> PASS ***
    [/COLOR][/SIZE][/COLOR][/SIZE][SIZE=1][COLOR=#008000][SIZE=1][COLOR=#008000](000008)12/21/2012 14:03:01 PM - sss (192.168.1.109)> 230 Logged on
    [/COLOR][/SIZE][/COLOR][/SIZE][SIZE=1][COLOR=#000080][SIZE=1][COLOR=#000080](000008)12/21/2012 14:03:01 PM - sss (192.168.1.109)> TYPE I
    [/COLOR][/SIZE][/COLOR][/SIZE][SIZE=1][COLOR=#008000][SIZE=1][COLOR=#008000](000008)12/21/2012 14:03:01 PM - sss (192.168.1.109)> 200 Type set to I
    [/COLOR][/SIZE][/COLOR][/SIZE][SIZE=1][COLOR=#000080][SIZE=1][COLOR=#000080](000008)12/21/2012 14:03:01 PM - sss (192.168.1.109)> PORT 192,168,1,109,4,17
    [/COLOR][/SIZE][/COLOR][/SIZE][SIZE=1][COLOR=#008000][SIZE=1][COLOR=#008000](000008)12/21/2012 14:03:01 PM - sss (192.168.1.109)> 200 Port command successful
    [/COLOR][/SIZE][/COLOR][/SIZE][SIZE=1][COLOR=#000080][SIZE=1][COLOR=#000080](000008)12/21/2012 14:03:01 PM - sss (192.168.1.109)> RETR 20121221151636565.pdf
    [/COLOR][/SIZE][/COLOR][/SIZE][SIZE=1][COLOR=#008000][SIZE=1][COLOR=#008000](000008)12/21/2012 14:03:01 PM - sss (192.168.1.109)> 550 File not found
    [/COLOR][/SIZE][/COLOR][/SIZE][SIZE=1][COLOR=#000080][SIZE=1][COLOR=#000080](000008)12/21/2012 14:03:01 PM - sss (192.168.1.109)> PORT 192,168,1,109,4,18
    [/COLOR][/SIZE][/COLOR][/SIZE][SIZE=1][COLOR=#000080][SIZE=1][COLOR=#000080](000008)12/21/2012 14:03:01 PM - sss (192.168.1.109)> STOR 20121221151636565.pdf
    [/COLOR][/SIZE][/COLOR][/SIZE][SIZE=1][COLOR=#008000][SIZE=1][COLOR=#008000](000008)12/21/2012 14:03:01 PM - sss (192.168.1.109)> 150 Opening data channel for file transfer.
    (000008)12/21/2012 14:03:01 PM - sss (192.168.1.109)> 226 Transfer OK
    [/COLOR][/SIZE][/COLOR][/SIZE][SIZE=1][COLOR=#000080][SIZE=1][COLOR=#000080](000008)12/21/2012 14:03:01 PM - sss (192.168.1.109)> QUIT
    [/COLOR][/SIZE][/COLOR][/SIZE][SIZE=1][COLOR=#008000][SIZE=1][COLOR=#008000](000008)12/21/2012 14:03:01 PM - sss (192.168.1.109)> 221 Goodbye
    [/COLOR][/SIZE][/COLOR][/SIZE][SIZE=1](000008)12/21/2012 14:03:01 PM - sss (192.168.1.109)> disconnected.
    [/SIZE][SIZE=1]
    [/SIZE]
    The printer on the other hand, outputs: Sending the data has failed.
    Of course, my PDF file never shows up in the folder on the server either.
    The user in the address book, for the FTP settings, I just have the port # set, the server (called: server), no file path, and the username/password. if I put a path, it keeps reverting to SMB. When i remove the path, I can save the address book entry with FTP.
    Needless to say...i'm still stuck....
    • steve02a
      • 16
      #17
      So, I was working on this FTP issue yesterday. Two hours in, I still couldn't get it to work. My previous reply. Same issue. FTP connects then disconnects. Something is being very stubborn. I could connect via FTP to the server right from my laptop ...just client to server FTP. That works fine. I connect and can upload files. Why the printer can't connect when I clearly seeing making a connection. I wish I knew.
      Anyone have any suggestions?
      • rthonpm
        • Aug 2007
        • 2859
        #18
        If you're not specifying a folder on the server, just use / as the path. Also remember that FTP uses the web and Unix / instead of the Windows \ for directory levels. Using \ will always revert the setting to SMB.
        Also, this machine will not work at all with SMB to Server 2008. The Samba version on the network card is too old and doesn't support a high enough encryption level.
        • steve02a
          • 16
          #19
          I gave up trying to use SMB a while ago. It won't work. Someone suggested I probably need a firmware update - but I'm not going down that road. So now, I'm trying to get it work with FTP. I'll give the FTP a try using the "/" instead of the windows "\".
          • ruben
            The New Guy
            • Oct 2012
            • 1203
            #20
            (Windows can use both / and \ for pathnames).
            • mrwho
              Major Asshole!
              • 4299
              #21
              When setting up users in filezilla, it's common to forget to put the checkmark on the "write" permissions of the folder. Check it out.
              Mascan42
              Ibid
